Steering Wheel install, turn signal cancel |
spunone |
Mar 10 2008, 03:16 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Ok here's the issue removed steering wheel awhile back now did'nt mark location (IMG:style_emoticons/default/sad.gif) I have a used Momo with adapter ready to install .wheels on car are straight so which location do'es the turn signal cancel clip reinstall at? 9 oclock or 3 oclock Thanks
spunone |
Mar 10 2008, 04:58 PM
(IMG:style_emoticons/default/icon_bump.gif) Anybody come on somebody has to know (IMG:style_emoticons/default/pray.gif)
dw914er |
Mar 10 2008, 05:08 PM
Planning Cities Group: Members Posts: 2,364 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California |
you could do an trial/error thing
i personally dont know, but someone here has to speak up! |
t collins |
Mar 10 2008, 05:57 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
Looking at the backside it would be 9 oclock
spunone |
Mar 10 2008, 06:57 PM
So that will be the side with the turn signal lever correct?
t collins |
Mar 10 2008, 07:10 PM
Lets see if this clears things up a little. With the wheel mounted on the column the cancelation tab will be located on the backside at the 3 oclock position or close to the wiper lever.
Hope this helps. |
spunone |
Mar 10 2008, 07:13 PM
Gotcha Thanks . This is why I love this site
Mar 10 2008, 07:22 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
look at the turn signals ring.
There is a spring that comes out at about 1 and 5 oclock. the canceling tab hits that when you turn the wheel. make sure the spring is there. make sure the white little tabs do in fact attach to the spring still.. they tend to break off after 30 years. You can set the blinker and flick the spring with a screw driver to make sure it works. Lube it up. you can also use the four screws to adjust how sensitive it is to turn on and off... It seems to bind if the screws are to tight..and clicks off really fast if they are loose. Rich |
Lo-Fi Version | Time is now: 20th May 2024 - 04:46 PM |
