spunone
Mar 10 2008, 03:16 PM
Ok here's the issue removed steering wheel awhile back now did'nt mark location
I have a used Momo with adapter ready to install .wheels on car are straight so which location do'es the turn signal cancel clip reinstall at? 9 oclock or 3 oclock Thanks
spunone
Mar 10 2008, 04:58 PM
Anybody come on somebody has to know
dw914er
Mar 10 2008, 05:08 PM
you could do an trial/error thing
i personally dont know, but someone here has to
speak up!
t collins
Mar 10 2008, 05:57 PM
Looking at the backside it would be 9 oclock
spunone
Mar 10 2008, 06:57 PM
So that will be the side with the turn signal lever correct?
t collins
Mar 10 2008, 07:10 PM
Lets see if this clears things up a little. With the wheel mounted on the column the cancelation tab will be located on the backside at the 3 oclock position or close to the wiper lever.
Hope this helps.
spunone
Mar 10 2008, 07:13 PM
Gotcha Thanks . This is why I love this site
r_towle
Mar 10 2008, 07:22 PM
look at the turn signals ring.
There is a spring that comes out at about 1 and 5 oclock.
the canceling tab hits that when you turn the wheel.
make sure the spring is there.
make sure the white little tabs do in fact attach to the spring still..
they tend to break off after 30 years.
You can set the blinker and flick the spring with a screw driver to make sure it works.
Lube it up.
you can also use the four screws to adjust how sensitive it is to turn on and off...
It seems to bind if the screws are to tight..and clicks off really fast if they are loose.
Rich
