914-6 rear emblem hole locations, Looking for hole locations |
John |
Mar 12 2008, 09:17 PM
Could someone measure the hole locations for an original 914-6 emblem.
I need a starting point. I know center to center dimensions for the holes. If I could get a height and a distance for one of the 3 holes, it would be a starting point. Thanks. |
914Sixer |
Mar 14 2008, 12:32 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Do you have a 914-6 emblem? Take it and press it into a piece of cardboard. You should be able to use those holes for your drilling pattern. Cut the cardboard down to size and use it to center it where you want it.
70Sixter |
Mar 15 2008, 10:57 AM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
From the right tail lite to the rt edge of the 6 is 1 7/8" and from the lip below the 6 to the bottom of the 6 is 1 7/8". I can measure the hole, but the reference points are less clear
Sorry, accidental discharge. See next |
70Sixter |
Mar 15 2008, 11:01 AM
From the left side of the right tail lite to the rt edge of the 6 is 1 7/8" and from the lip below the 6 to the bottom of the 6 is 1 7/8". I can measure the holes, but the reference points are less clear.
If you make the template 914Sixer suggested you should be good. |
John |
Mar 17 2008, 07:12 PM
From the left side of the right tail lite to the rt edge of the 6 is 1 7/8" and from the lip below the 6 to the bottom of the 6 is 1 7/8". I can measure the holes, but the reference points are less clear. If you make the template 914Sixer suggested you should be good. Thanks, That should get me real close. I don't want to install it where it doesn't look right. John |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:55 AM |
