3 Pages V < 1 2 3
> What Welder to buy, I show my ignorance inside!
Gint
post Jan 19 2004, 01:46 PM
Post #41
Mike Ginter
LOL. I bought my Miller 175 (220V) so I wouldn't have to haul it around. Damn thing is heavy too.
If I had gone with a 110V though, it would have been the Miller 135 or the Hobart. Both are very good equipment.
This post has been edited by Gint: Jan 19 2004, 01:51 PM
eldiosyeldiablo
post Jan 21 2004, 09:28 PM
Post #42
How is the Lincoln Electric Well Pak 3200 HD. I found a refurbished one for $375 at Home Depot in Atlanta. Looks like it is missing the instructions but that is about it as far as I can tell.
I'm probably a good 3+ months off before I attempt anything.
Is this a very good buy or let it pass?
-David
eldiosyeldiablo
post Jan 22 2004, 03:28 PM
Post #43
bump?
No reponses so I'll pass on it then.
Jeff Bonanno
post Jan 22 2004, 04:27 PM
Post #44
il dottore
Lincoln Electric 3200 HD specs
at least you wouldn't have to rewire the garage!
jbb
BGman
post Jan 22 2004, 07:13 PM
Post #45
Greg
my .02,
I am not a great welder....but I work around several excellent fab welders. When I was looking for a 110 unit, all three recommended to spend the extra cash and get the Miller 135. As far as mig welders go- they all agreed that it was worth the premium. When you are learning (and if you can afford it) it pays to work with a quailty system. I have welded on everything from sheet-metal to 8" pipe- it is a great machine.
-g
Sammy
post Jan 25 2004, 03:40 AM
Post #46
Uhhhhmmmm,
A stick welder and a wire feed welder are both MIG welders.
They are also both electric arc welders.
For sheet metal you want a gas shielded wire feed welder.
Flux core wire feed MIGs are known for excessive splatter and welds that are not as clean or pretty but are usually cheaper to buy.
For heavier stuff (and for experts) stick MIG welders are fine. They are even less money that a flux core welder.
BTW I love Harbor freight tools but the biggest dissapointment I've had there so far was the flux core wire feed MIG I bought from them. It is 120 vac and is just about useless. I would not recommend buying a chicago electric welder.
I have a miller ar work and it works very well.
(IMG:style_emoticons/default/givemebeer.gif)
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 4th July 2025 - 06:19 PM
