Switching to Carbs - Which Distributor?, Have one from D-Jet and one from L-Jet |
vesnyder |
Mar 16 2008, 11:42 AM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
Just rebuilt my motor and switched to carbs and would ultimately want to buy the Mallory Unilite, but in the meantime I would like to run my motor with one of my existing distributors. The motor has new P&C's and is now a 1911 with the new cam and heads. I have the distributor from a D-Jet and another from an L-Jet - which one should I use and what should I do about the vacuum advance? Or should I just wait until I purchase the Unilite?
Thanks |
cgnj |
Mar 16 2008, 03:02 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Hi,
I have always gone aftermarket for a distibutor with caqrbs. In the past, I have read and looked at the relative advance curves for djet and ljet distributors. I have read that the ljet distributors have a better advance curve for carbs. I run a mallory. If I had to run a stock distrbutor, I would tune one, pull it, measure the other. I would use the distributer that gave me the most mechanical advance from idle to full advance, and start saving for a mallory. I do use the vacum advance in my mallory. It is only for cruising high rpm, high vacum to increase gas mileage. If your running carbs this should be a non-issue. I will be moving my 1.7 mule this week. I can pull out the timing gun and give a definitive answer regarding the merits of the djet/ljet distributor advance curve question later this week. carlos |
Mar 16 2008, 03:25 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Run the L-jet one until you can save up for the Mallory.
--DD |
pete914 |
Mar 16 2008, 04:18 PM
Member Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 |
I agree. L -jet vacuum advance dizzy
vesnyder |
Mar 16 2008, 04:26 PM
Thanks guys. I will run the L-jet, but what should I do about the advance - ignore it? Is there any where I can connect it to?
Gint |
Mar 16 2008, 08:59 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
If you're referring to the vacuum advance, yes, ignore it. The can on the dizzy won't do any advance or retard if a hose isn't hooked up. You'll be running strictly on mechanical advance. That's OK. With the L-Jet dizzy it's not optimal, but it's OK.
vesnyder |
Mar 17 2008, 05:19 AM
Grat guys - Thanks! Full steam ahead on the assembly at least until my next question?
Lo-Fi Version | Time is now: 14th May 2024 - 12:48 AM |
