Help W/ Steering Column. . |
914ghost |
Jan 13 2004, 09:31 PM
BOB Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 |
Hi guys & gals. .
in my quest to keep myself occupied I decided to remove the ignition switch to re-key to the door key. Anyhow, I have a 70' and couldn't find a reference ANYWHERE about the early style column. Nobody cares. . (IMG:style_emoticons/default/sad.gif) You know the HAYNES manual doesn't even mention an Ignition switch!? assholes. (IMG:style_emoticons/default/mad.gif) I figured out how to get the switch out, it wasn't too hard. But turns out you gotta CUT the wires, there are NO plugs on the back- the wires are threaded through from the steering wheel side. Sucks. (IMG:style_emoticons/default/wink.gif) Question, how interchangable are the early / late columns? I'd like to upgrade to have the wiper switch on the column and use my wiper switch for foglights. Can I even use my steering wheel on a late column? I got a funny feeling it aint straight forward though- Thanks once again for advice- Robert O |
hargray2 |
Jan 13 2004, 09:42 PM
fuh-q Group: Members Posts: 302 Joined: 12-December 03 From: hardeeville,sc Member No.: 1,432 |
I think the early and late columns have different electrical connectors. If I remember correctly, the early cars have a wide connector with a bakelite housing and the late cars have two square white plastic connectors. I believe your steering wheel would interchange though.
Jan 13 2004, 09:45 PM
i've done exactly that, from '70 to '73 ...
major PITA! (IMG:style_emoticons/default/smash.gif) and i replaced my complete wire harness with a '73. which made it a lot easier. bottomline, most of the wires won't fit a late column if you don't replace the harness. the wiper switch on yours is on the dash, not the column. you would have to really hack into to harness to make that work. as for the hardware: - the "receiver" where the column bolts onto the body is a different size. the bolt spacing is OK, but you have to trim the sides of the mounting plate to fit. - the part of the shaft that runs down between the top joint and the lower joint has a slightly different length and the "grooves" for the bolts are spaced different. you can use the later style shaft, but you have to grind new "grooves" Andy |
914ghost |
Jan 13 2004, 09:51 PM
Sh*t. .I figured as much.
I fI could get the connectors with the late shaft, it would just be a matter of "wiring it up" but the hardware problem sounds like more of a pain. I did figger out though, just now, the very very small little tiny itty bitty set screw in the side of the switch housing allows teh electrical part to be removed. I though it was for the switch tumblers. I noticed that as I was removing it if you try real hard you can get the switch out just far enough to peek at this screw. If I had unscrewed it then, my wires would be intact. (IMG:style_emoticons/default/headbang.gif) pssshhh. . R O |
Lo-Fi Version | Time is now: 15th May 2024 - 01:35 PM |
