Alternate reverse switch connections, Need a hook-up! |
GS Guy |
Mar 18 2008, 05:48 AM
Member Group: Members Posts: 243 Joined: 8-July 04 From: Columbia, MD Member No.: 2,325 Region Association: North East States |
Is there some kind of special plug or connection that goes to the reverse light switch on the transaxle? I just got the tranny all back together, now trying to figure out how to wire the reverse switch.
Since this is a custom installation, no existing wiring harness to "reconnect". Is the switch plug available as a separate replacement part? Doc E recommended just soldering some wires into the switch and make up my own plug - which I'm not opposed to doing but keeping in mind the switch is an $85 replacement part, I don't want to muck it up! Any other options for hooking up the switch (replacement plug sources, or alternate non-stock solutions)? I just want a reliable connection without dropping a ton of $$! Jeff |
914Sixer |
Mar 18 2008, 06:44 AM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Go to your local auto parts store and get 2 bullet connectors that fit your switch. Probably less than $.50 each. Crimp them on and check your connection. I would recommend you getting the rubber boot cover though.
SirAndy |
Mar 18 2008, 10:57 AM
Resident German Group: Admin Posts: 41,650 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Go to your local auto parts store and get 2 bullet connectors that fit your switch. Probably less than $.50 each. Crimp them on and check your connection. I would recommend you getting the rubber boot cover though. (IMG:style_emoticons/default/agree.gif) the two bullet connectors simply slide into the switch, order doesn't matter. a rubber boot keeps the dirt out ... (IMG:style_emoticons/default/shades.gif) Andy |
Lo-Fi Version | Time is now: 20th May 2024 - 08:50 AM |
