Time to go pressure test the new fuel lines, I hate plumbing. |
DNHunt |
Mar 19 2008, 07:01 AM
I dumped 3 gallons of ethyl in thank to static test the lines and about a cup dripped out of 1 filling. I forgot to tighten it. DOH! I cleaned up the spill and bleed the line to the pump so I got the sleaves of my sweatshirt soaked in gas. I'm about ready to put juice to the pump and set static fuel pressure to 40 psi.
I hate plumbing Dave |
ConeDodger |
Mar 19 2008, 07:19 AM
Apex killer! Group: Members Posts: 23,580 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Dave,
Are you using the SS tunnel lines from Chris Foley? I did. They work slick. No worries about what is going on between the front and back. What are you using for TB, injectors, and what sensors are you using with your SDS? |
DNHunt |
Mar 19 2008, 07:33 AM
No,
I have some lines I ran several years ago. They are fine. The new stuff is frome them to a new fuel filter and then to the pump. It's all hard line I bent. I've just had to tighten the flared fittings more. I'm giving it plenty of time until I run the pump. The trottle bodies are TMW 45's Injectors are Ford Red tops (30lbs at 43 psi). The sensors are the ones supplied by SDS. Intake air sensor is A GM bird cage. CHT is a Bosch 012 like a 74 2.0l. TPS is a unit supplied by Jake. MAP sensor is supplied by SDS in the kit. I've set up an intake air valve I got off some VW Golf years ago for warmup. The only trick was Jake put a .035 welding tip in the vacuum line to the MAP sensor for metering the vacuum. It evens out the pulses from the ITBs. Dave |
rhodyguy |
Mar 19 2008, 07:36 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
wednesday...car day...i'm going to swing by on the way north. gotta infuse some cash into the good to go account anyway.
k |
DNHunt |
Mar 19 2008, 07:46 AM
Great Kevin.
I'll be here until 2 for sure Dave |
rhodyguy |
Mar 19 2008, 07:56 AM
around 8.
k |
ericread |
Mar 20 2008, 12:59 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
How hard is it to install the SS fuel lines in the tunnel??? I'd really like to do this but I'm afraid... very afraid... (IMG:style_emoticons/default/sad.gif)
roadster fan |
Mar 20 2008, 01:12 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
How hard is it to install the SS fuel lines in the tunnel??? I'd really like to do this but I'm afraid... very afraid... (IMG:style_emoticons/default/sad.gif) Easy. took me 45 minutes by myself including removing the old plastic ones. Jim |
rhodyguy |
Mar 21 2008, 07:31 AM
what did mallory tell you about the return outlet? closed loop and return to the tank?
k |
DNHunt |
Mar 21 2008, 07:39 AM
Yep,
I had it plumbed right. No joy, I'm still struggling with low pressure. I've got everything out of the car so I can bench test it. It's looking more like the pump will have to go back to Mallory. So everything will be on hold for who knows how long. Man, I'm getting tired. If I had beach front, the whole thing would be at the bottom of the Sound and I'd be dealing with the Coast Guard. Das Boot II. By the way, all you vultures keep your distance. |
rhodyguy |
Mar 21 2008, 07:44 AM
so...the return line comes off of one of the rails, or out of the regulator as i guessed? confused. there's still time to del/web that pup out and be done with it. (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/laugh.gif)
k |
DNHunt |
Mar 21 2008, 07:46 AM
I' not putting carbs on it. It'll either run the way I want it or it'll sit and rot.
DNHunt |
Mar 21 2008, 07:58 PM
Man, I kinda went off. I fixed the SOB pump. It had a bleed valve problem.
messix |
Mar 21 2008, 08:35 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/slap.gif)
now go get some of this (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 10th May 2024 - 12:19 AM |
