Converting to 911 Steering Column ... |
SirAndy |
Mar 20 2008, 01:35 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I went ahead and ordered all the parts needed to convert my currently trashed steering column to a 911 unit with the 911 keyswitch and column lock ...
i should have all the parts early next week. i'll post pictures of the install as i go along ... (IMG:style_emoticons/default/piratenanner.gif) Andy |
MrKona |
Mar 20 2008, 02:00 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
Andy,
Glad to see you're "taking back" your 914. May be a dumb question - but is there a benefit of the 911 column over the 914? Bolt in application? - Bryan |
SirAndy |
Mar 20 2008, 02:06 PM
is there a benefit of the 911 column over the 914? Bolt in application? well, porsche once used the tagline "a real porsche has the ignition key on the left side" ... (IMG:style_emoticons/default/rolleyes.gif) my column is busted (dam thieves (IMG:style_emoticons/default/dry.gif) ) so i need a replacement anyways so why not use the 911 column to up the cool factor of the car at the same time? the column needs some minor welding (adding a 914 mount) and you have to adapt the wiring, but 911 parts are readily available and it's really not that much work ... (IMG:style_emoticons/default/bye1.gif) Andy |
Lo-Fi Version | Time is now: 28th April 2024 - 02:29 AM |
