Converting to 911 Steering Column ... |
SirAndy |
Mar 20 2008, 01:35 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I went ahead and ordered all the parts needed to convert my currently trashed steering column to a 911 unit with the 911 keyswitch and column lock ...
i should have all the parts early next week. i'll post pictures of the install as i go along ... (IMG:style_emoticons/default/piratenanner.gif) Andy |
ClayPerrine |
Mar 21 2008, 07:12 AM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You do realize that I did this already? (IMG:style_emoticons/default/biggrin.gif)
the mounting plate on a real 914/6 column will not fit a later car. You have to cut the mounting plate off a 4 cylinder column and weld it to the 911 column. You need the metal area in the dash for the ignition lock surround, because the 911 column is flat to the dash, and the 914 column tilts upward slightly. You also have to trim the top of the clamshells to clear the tach, and you have to make a trip piece for the lock, as the factory one is NLA. I have pictures on my computer at home. If you run into problems, give me a call. |
Lo-Fi Version | Time is now: 28th April 2024 - 04:30 AM |
