CB rotary fuel pump, went to heaven |
Elliot Cannon |
Mar 21 2008, 06:31 PM
I finally installed a new (used) fuel tank. I poured fuel in and tried to start it up. The pump came on for a few seconds then quit. Could it have failed because it had been dry for a few weeks? Anyone had this or something similar happen?
Cheers, Elliot |
KaptKaos |
Mar 21 2008, 07:52 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Obviously the car is defective. I'll drive up and take that for you. (IMG:style_emoticons/default/biggrin.gif)
toon1 |
Mar 21 2008, 08:37 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Yea that car sucksssss! I will take it off your hands,LOL
The pump are designed to run for three seconds and quit if the engine is not running. It's a saftey feature. But it your case, it's the car, can I have it!!?? |
Elliot Cannon |
Mar 21 2008, 09:23 PM
You bozos thought it was the other one didn't ya? They both need fuel pumps now!!
Attached thumbnail(s) |
KaptKaos |
Mar 22 2008, 12:03 AM
Ok, fine. I'll take the black one I guess.... (IMG:style_emoticons/default/av-943.gif)
swl |
Mar 22 2008, 06:31 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
No bad choices trying to nick one of your cars!
I doubt that dry for only a few weeks would hurt it unless it built up heat before it had fuel to cool it. I doubt that though - maybe in a high pressure diesel fuel pump but not on a carb pump. Have you given it a little tap to get it going? Confirmed power to the pump? OT: That's a real interesting wheel brake combo on the black car. Is there a thread on that anywhere? |
Lo-Fi Version | Time is now: 20th May 2024 - 10:29 AM |
