Oil temp sender, Routing.... |
914werke |
Mar 22 2008, 09:40 PM
"I got blisters on me fingers" Group: Members Posts: 10,060 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
For those of you with a car that came with a console
there is a coresponding "taco plate" assemb. at the bottem of the engine. It is a plate and sender, gasket, then coverplate with stand to hold the associated green wire with grey sheath. As the wire is routed over the engine there are at least one (two?) tabs that pinch and hold that wire until it passes thru the gromet and connects to the harness. Does anyone have pics or can explain where the tabs get mounted (IMG:style_emoticons/default/confused24.gif) Its been so long since I tore it apart that I can remember exactly where they go. (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/wub.gif) |
McMark |
Mar 23 2008, 12:43 PM
IIRC, one tab mounts on the upper oil filter console stud, and one mounts on the bolt that connects the oil cooler to the impeller housing.
914werke |
Mar 24 2008, 10:00 PM
Thanks Mark. No Pics? Anyone else?
orange914 |
Mar 25 2008, 12:08 AM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Thanks Mark. No Pics? Anyone else? this will be good to know... (IMG:style_emoticons/default/icon_bump.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 10:06 AM |
