V8 throttle linkage - update, ** short video added today ** |
jimkelly |
Mar 27 2008, 01:15 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
last year root and i got my 1972 v8 914 on the road - but i felt like power was low and that the 4 barrels were not opening up. the last time i was at root's he watched the linkage at the carb to see what kind of range i was getting - it was about 50%.
well yesterday i made an adjustment - and have dramatically increaed the range but still not enough to get the 4 barrels to kick in. regardless - she hauls ass now (IMG:style_emoticons/default/biggrin.gif) i do not use 1st gear - i use 2nd as first - and moments ago i had her at 100mph in 4th - i sorts felt like i was in a space shuttle about to break thru the atmosphere. i think i need chuck yeager to see what top speed is - as currently set up - cause i ain't got the balls to find out for myself (IMG:style_emoticons/default/popcorn[1].gif) Attached image(s) |
LvSteveH |
Mar 27 2008, 01:55 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
You've got the right idea, moving it closer to the throttle shaft centerline. I usually pull from the other side, but as long as your cable is long enough it doesn't really matter.
It's hard to tell from the pics, but I probably wouldn't go any closer than you have it now. Chances are your problem is down at the pedal. You need to check the throttle stop and make sure there's no carpet etc in the way. If you can't resolve it that way or by lengthening the pedal rod then it's similar to what you did with the carb linkage. You can lengthen the arm on the pedal cluster where the throttle cable attaches. You don't want to make it too long or the throttle will be an on/off switch, but it shouldn't take much to get it set up properly. |
messix |
Mar 27 2008, 02:20 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
get rid of that coffe stir straw of a air filter.
jimkelly |
Mar 27 2008, 04:03 PM
thanks guys.
yeah - are filter has got to be replaced with a bigger one : ) linkage at the peddle - i need to look at that. jim |
Dr. Roger |
Mar 27 2008, 04:24 PM
Hey Jim, it's easy to check your pedal. Just get your head down there and push on the pedal and see how much the throttle linkage travels. It really isn't very much as I found the first time around. Getting closer to the throttle plate shaft did fix my issue.
What sucks is that the ideal place for the cable to connect is between the two pre-existing holes. Of course. (IMG:style_emoticons/default/dry.gif) You'll get it right. I've got faith in ya'. (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/driving.gif) |
jimkelly |
Mar 27 2008, 04:32 PM
the adjustment i did probably is letting me experience about 225-250 hp or so. wow - driving this thing is getting funner by the minute : ))
can't wait to be putting all my ponies to the pavement. i will try to get a video soon. jim |
drive-ability |
Mar 27 2008, 10:02 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
I had a similar deal, I made a extension on the throttle pedal side, turned out to work perfict... I'll look for a picture
jimkelly |
Mar 28 2008, 06:56 PM
Dr. Roger |
Mar 28 2008, 08:40 PM
Hey Jim!
That car of yours sounds great. A sleeper with a little attitude. I was crackin' up listening to the soundtrack on your video. (IMG:style_emoticons/default/laugh.gif) |
jimkelly |
Mar 29 2008, 05:09 AM
dr
thanks - my son took about 10 little videos - at first i thought none were good enough to share - but this one is a gem. i wanted to show the acceleration - but humor is ok too : ) jim |
Lo-Fi Version | Time is now: 16th May 2024 - 01:13 AM |
