Engine is going in today, Engine porn |
DNHunt |
Mar 29 2008, 09:58 AM
But first, here was a head scratcher. Early EA case with a side shift bar. If your block off plate is too thick there can be a problem. Thank God for grinders.
Dave |
DNHunt |
Mar 29 2008, 10:05 AM
Here's the package. Fuel injected 2270 with individual throttle bodies
45mm TWM throttle bodies Something is missing. I'll be running crankfire ignition |
DNHunt |
Mar 29 2008, 10:10 AM
Chris Folley's headers
I run the oil cooler down low and duct air to it from under the car. There is a small scoop that replaces the driver's side air deflector. |
effutuo101 |
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
(IMG:style_emoticons/default/drunk.gif) Looking good! More pictures please!
DNHunt |
Mar 29 2008, 10:13 AM
In the center of the engine is a idle air control valve and a small air filter. It acts like the AAR on the d-jet so it speeds up the idle during warm up except, it is either open or closed
DNHunt |
Mar 29 2008, 10:16 AM
It should be interesting getting this under the drive shafts. I'm planning to start it under the car side ways and rotate it so the ITBs clear. We'll see
Dave |
ConeDodger |
Mar 29 2008, 10:18 AM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Dave,
You can do that tomorrow. Get on down here to the Porsche Family Reunion. (IMG:style_emoticons/default/biggrin.gif) Seriously, Be safe. Good luck... |
restore2seater |
Mar 29 2008, 10:40 AM
Future 914 copilot. Group: Members Posts: 311 Joined: 30-October 04 From: Dunlap,IL Member No.: 3,037 Region Association: None |
But first, here was a head scratcher. Early EA case with a side shift bar. If your block off plate is too thick there can be a problem. Thank God for grinders. Dave Dave, Is this case different from the one that you have been using? I was under the impression that the problem was the cylinders being washed down from an overly rich mixture. Was there a problem with your case too? Just curious. |
PeeGreen 914 |
Mar 29 2008, 10:56 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Sweet Dave
So are you going to bring this to a PCA AX so we can see it in action? At least come out so we can see it (IMG:style_emoticons/default/wink.gif) I just bought a 2.4l and it should be in my car in about a month or so. |
rhodyguy |
Mar 29 2008, 04:40 PM
yipeeeee.
k |
Aaron Cox |
Mar 29 2008, 05:43 PM
lookin good....
DNHunt |
Mar 29 2008, 05:47 PM
Engine is in and everything under the car is hooked up. I got to that point and just ran out of gas. So, I stopped for (IMG:style_emoticons/default/beer3.gif) . The problem is at my age that just makes me tired. So, beer and hoops for the remainder. The only thing different under the car is a heat exchanger on the starboard side. It tees for air on both sides.
Package is in. This is the first time the car has been on the ground since Thanksgiving. (IMG:style_emoticons/default/piratenanner.gif) I'll hook up the topside tomorrow morning and light it off after church. This is a new case that i sent to Jake for decking. The last case got a sh*tload of crap from 3 busted pistons. It was easier to replace it than try to clean it. I hope to run at Bremerton but, it may be a while. Mice nested in my helmet this winter (IMG:style_emoticons/default/headbang.gif) . I got so p*ssed I Deconned the bunch of them. It didn't help the helmet though. Dave |
McMark |
Mar 29 2008, 05:48 PM
I'm excited for you Dave! (IMG:style_emoticons/default/boldblue.gif) Keep us posted!
Couple things: EA case with an open front oil port? Only bus cases had that opened up... (IMG:style_emoticons/default/confused24.gif) I had to install the headers after the motor was in. (IMG:style_emoticons/default/sad.gif) How'd you sneak it in? |
effutuo101 |
Mar 29 2008, 06:23 PM
Looking good Dave! Take video tomorrow.
DNHunt |
Mar 29 2008, 06:53 PM
KELTY360 |
Mar 29 2008, 06:57 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) So you keep KY in the toolbox? |
mstein95 |
Mar 29 2008, 08:01 PM
Back when grey Levi's were the rage. Group: Members Posts: 404 Joined: 1-May 06 From: Eugene, OR Member No.: 5,959 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/clap56.gif)
WOW!! AWESOME DAVE!! Finally got mine running. Turns out I learned from the best (you) - had my distributor off 180 degrees. Need to adjust the valves again and I think I'm good to go. Hope to see you all in Seattle this summer. |
ConeDodger |
Mar 29 2008, 08:10 PM
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) So you keep KY in the toolbox? This is California. We all keep KY in our toolbox. (IMG:style_emoticons/default/biggrin.gif) |
KELTY360 |
Mar 29 2008, 08:33 PM
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) So you keep KY in the toolbox? This is California. We all keep KY in our toolbox. (IMG:style_emoticons/default/biggrin.gif) Synthetic or dino? (IMG:style_emoticons/default/idea.gif) |
DNHunt |
Mar 29 2008, 09:10 PM
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) So you keep KY in the toolbox? Dielectric Grease |
Lo-Fi Version | Time is now: 16th May 2024 - 01:54 PM |
