Tailshift to side shift conversion?, What all is required for the swap? |
JRust |
Mar 30 2008, 10:26 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Hey gents I am converting my 70 914-8 with a tailshift to a sideshift. My question is the linkage completely different front to back? Or is it just from the firewall back. I have everything to do it front to back but wondered if it was all needed. Not sure if the linkage in the center tunnel along with the shifter are different between the 2 setups. Just don't want to go thru the hassle of swaping parts that don't need swapped.
As far as having everything I am sure I need some new bushings. What else do I need? Also on my side shift tranny the case is chipped where the odometer cable screws in. I have a parts tranny. Will that whole rear piece come off easily? Any tricks I need to know to swap that back piece? Thanks in advance |
brant |
Mar 30 2008, 10:34 PM
this comes up about 1x a month
you need the actual shifter and the front rod parts.... mounts, etc Check Here |
9146FAN |
Mar 30 2008, 10:41 PM
Member Group: Members Posts: 294 Joined: 20-July 04 From: ROSSMOOR, CA Member No.: 2,378 |
I did the conversion for my six. You will need specific "side-shifter" parts as follows:
Shifter Shift Rod In Tunnel Shift Rod from firewall to trans with Coupler Bushing at Firewall to convert Linkage Boot and Cover Rear linkage swivel with cup bushing + Side-Shift Transmission, or convert your old real shift trans: all 3 Internal Trans Shift Rods with selectors and Forks Side Shift Linkage Console Rear Trans Cover It's a lot of work, but it will make a major difference. On a V-8, you may need to fabricate the rear linkage rod. |
biosurfer1 |
Mar 30 2008, 11:27 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
I did this conversion while the good Dr. was rebuilding my tranny... all I can say is be careful when you finish and shift how you think it should shift, not how it was shifting. My 1st gear was way off, same with 4th...after the rebuild and conversion I kept looking for them where they used to be, but now everything lines up the way it should.
sounds weird but you'll see. |
Bills914-4 |
Mar 31 2008, 03:46 AM
Member Group: Members Posts: 310 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
Maybe I'm wrong, but I thought you have to change the Engine Mount & Bar. If not all the better (maybe I need to give the good DR. a call and change my plans) Thanks Bill |
jr91472 |
Mar 31 2008, 06:45 AM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Maybe I'm wrong, but I thought you have to change the Engine Mount & Bar. If not all the better (maybe I need to give the good DR. a call and change my plans) Thanks Bill Yes, engine mount bar must be switched out as well. Not to mention the associated inboard and outboard engine mounts. But the knob on your shifter is compatible (IMG:style_emoticons/default/biggrin.gif) Everything else...not so much. |
rhodyguy |
Mar 31 2008, 07:14 AM
jamie, can you post a picture of the current engine support bar/engine attachment setup?
k |
JRust |
Mar 31 2008, 08:37 AM
The engine mount bar I think will be okay. Looks like there is the space needed but I'll take that rear piece of linkage & see what it looks like next to it. I kind of suspected the whole side shift setup needed to go in. Just making sure!
I plan on replacing all the bushings. There is a kit that includes all the bushings on the Bird for like $55. It is specific for a sideshift conversion. SO I am assuming there must be a slight difference in the bushings. Ealry linkage to late? Different diameter of the actual linkage maybe? Anyway I'll be ordering it later today. Thanks for the help & the link. I want to get it right & make sure I have everything needed. Nothing worse than starting something & being short a part. Then having to wait a week for the part so you can finish (IMG:style_emoticons/default/headbang.gif) |
GeorgeRud |
Mar 31 2008, 08:41 AM
If you're putting a side shifter system into an early car, you need the firewall bushing that holds the later style, smaller diameter bar in the early, larger hole in the firewall.
Basically, change every part between the shift knob to the transmission. It does make a difference however! |
Trevorg7 |
Mar 31 2008, 08:58 AM
Senior Member Group: Members Posts: 1,242 Joined: 7-December 04 From: Highland Village, TX Member No.: 3,241 Region Association: Southwest Region |
this comes up about 1x a month you need the actual shifter and the front rod parts.... mounts, etc Check Here Check the link Brant posted, which is quoted above. Within the thread there is a pretty good list of what is needed. T |
Lo-Fi Version | Time is now: 16th May 2024 - 03:48 AM |
