peddle assy - came apart : ((( |
jimkelly |
Mar 31 2008, 08:47 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
are the two parts arrowed in purple supposed to come apart ???
jim while rerouting my throttle cable - and almost done - this comes apart : (( Attached thumbnail(s) |
race914 |
Mar 31 2008, 08:53 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
That is where you disconnect the throttle cable from the pedal assembly. It is supposed to come apart with some leverage applied, but not just fall apart.
The ball socket must have worn out for it to fall apart like that. See part #6 |
StratPlayer |
Mar 31 2008, 08:54 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Yes they come apart, I usually seperate the rod when I'm working on a clutch or throttle cable. It will just snap back onto the ball of the peddle cluster and then to the back of your gas peddle.
jimkelly |
Mar 31 2008, 10:15 AM
it snaps on but pops right off with small movement. the lever that has the balls flops side to side - guess it is not supposed to do this ? jim
rjames |
Mar 31 2008, 11:05 AM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE the lever that has the balls flops side to side (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/av-943.gif) Sorry, I'm easily amused this morning. (IMG:style_emoticons/default/biggrin.gif) |
messix |
Mar 31 2008, 11:57 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
QUOTE the lever that has the balls flops side to side (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/av-943.gif) Sorry, I'm easily amused this morning. (IMG:style_emoticons/default/biggrin.gif) can you tie them in a knot? |
PeeGreen 914 |
Mar 31 2008, 12:37 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Jim... you're correct on this. It is only supposed to pivot forward and backwards.
TINCAN914 |
Mar 31 2008, 02:09 PM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
I had the same probem last summer. Try a pair of ppliers to snap it back on. I had to use a little pressure...
Mar 31 2008, 02:29 PM
inside the cup portion is a small round clip that expands when you insert the ball.
See if that is still there. Rich |
jimkelly |
Mar 31 2008, 02:36 PM
rtowle - yes - the clip is still in there - thanks
because if the slop in the movement of the dual ball arm - i decided to remove the peddle assy and rebuild it. jim Jim... you're correct on this. It is only supposed to pivot forward and backwards. Attached thumbnail(s) |
Mar 31 2008, 02:45 PM
Get a new ball and cup.
George at AA has them and its worth it at this point. Use the brass bushings instead of the nylon (again George has them) This is a much better setup that can be lubed and wont bind. Now, you need to get the pressed in pin out...not a great thing to do. Use the correct sized punch, not a nail or a nail set...get the right punch or you will be sorry. Its in there and rusted. Rich |
McMark |
Mar 31 2008, 04:08 PM
Your throttle linkage arm looks a little bent. I just dealt with one where the welds holding the rod to the arm were failing. Zapped it back into place. The rod and the arm should be about a right angle to each other.
jimkelly |
Mar 31 2008, 04:27 PM
a little better pic
McMark |
Mar 31 2008, 07:21 PM
Still looks bent to me. Pull out the pin and remove it. Clean it up and check for cracking.
Mar 31 2008, 07:47 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
race914 |
Mar 31 2008, 08:05 PM
One for comparison
race914 |
Mar 31 2008, 08:17 PM
Another pic for comparison. Hope it helps
jimkelly |
Mar 31 2008, 08:21 PM
thanks for the pics - i will take a closer look at mine tomorrow.
jim |
root |
Mar 31 2008, 08:52 PM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
thanks for the pics - i will take a closer look at mine tomorrow. jim I might have bent it the day I drove it back from Summer Duck (IMG:style_emoticons/default/driving.gif) It probably happened when I spanked that BMW 320i on Rt66 East. (IMG:style_emoticons/default/aktion035.gif) I was just trying to get more throttle out of it! (IMG:style_emoticons/default/av-943.gif) |
jimkelly |
Apr 1 2008, 07:11 AM
you are one competitive engineer : )
i notice my shifter is bent too (see pic ) : ) that bmw must have really been something : ) * you will not believe how powerful 914v8 is when full throttle range is available to the gas peddle - much more similar to glenn's car than i ever thought it could be. jim -- thanks for the pics - i will take a closer look at mine tomorrow. jim I might have bent it the day I drove it back from Summer Duck (IMG:style_emoticons/default/driving.gif) It probably happened when I spanked that BMW 320i on Rt66 East. (IMG:style_emoticons/default/aktion035.gif) I was just trying to get more throttle out of it! (IMG:style_emoticons/default/av-943.gif) Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 12:04 AM |
