jimkelly
Mar 31 2008, 08:47 AM
are the two parts arrowed in purple supposed to come apart ???
jim
while rerouting my throttle cable - and almost done - this comes apart : ((
race914
Mar 31 2008, 08:53 AM
That is where you disconnect the throttle cable from the pedal assembly. It is supposed to come apart with some leverage applied, but not just fall apart.
The ball socket must have worn out for it to fall apart like that.
See part #6
StratPlayer
Mar 31 2008, 08:54 AM
Yes they come apart, I usually seperate the rod when I'm working on a clutch or throttle cable. It will just snap back onto the ball of the peddle cluster and then to the back of your gas peddle.
jimkelly
Mar 31 2008, 10:15 AM
it snaps on but pops right off with small movement. the lever that has the balls flops side to side - guess it is not supposed to do this ? jim
rjames
Mar 31 2008, 11:05 AM
Sorry, I'm easily amused this morning.
messix
Mar 31 2008, 11:57 AM
QUOTE(rjames @ Mar 31 2008, 10:05 AM)
can you tie them in a knot?
PeeGreen 914
Mar 31 2008, 12:37 PM
Jim... you're correct on this. It is only supposed to pivot forward and backwards.
TINCAN914
Mar 31 2008, 02:09 PM
I had the same probem last summer. Try a pair of ppliers to snap it back on. I had to use a little pressure...
r_towle
Mar 31 2008, 02:29 PM
inside the cup portion is a small round clip that expands when you insert the ball.
See if that is still there.
Rich
jimkelly
Mar 31 2008, 02:36 PM
rtowle - yes - the clip is still in there - thanks
because if the slop in the movement of the dual ball arm - i decided to remove the peddle assy and rebuild it.
jim
QUOTE(Phoenix 914-6GT @ Mar 31 2008, 11:37 AM)
r_towle
Mar 31 2008, 02:45 PM
Get a new ball and cup.
George at AA has them and its worth it at this point.
Use the brass bushings instead of the nylon (again George has them)
This is a much better setup that can be lubed and wont bind.
Now, you need to get the pressed in pin out...not a great thing to do.
Use the correct sized punch, not a nail or a nail set...get the right punch or you will be sorry.
Its in there and rusted.
Rich
McMark
Mar 31 2008, 04:08 PM
Your throttle linkage arm looks a little bent. I just dealt with one where the welds holding the rod to the arm were failing. Zapped it back into place. The rod and the arm should be about a right angle to each other.
jimkelly
Mar 31 2008, 04:27 PM
a little better pic
McMark
Mar 31 2008, 07:21 PM
Still looks bent to me. Pull out the pin and remove it. Clean it up and check for cracking.
Mar 31 2008, 07:47 PM
QUOTE(McMark @ Mar 31 2008, 06:21 PM)
race914
Mar 31 2008, 08:05 PM
race914
Mar 31 2008, 08:17 PM
Another pic for comparison. Hope it helps
jimkelly
Mar 31 2008, 08:21 PM
thanks for the pics - i will take a closer look at mine tomorrow.
jim
root
Mar 31 2008, 08:52 PM
QUOTE(jimkelly @ Mar 31 2008, 06:21 PM)
jim
I might have bent it the day I drove it back from Summer Duck
It probably happened when I spanked that BMW 320i on Rt66 East.
I was just trying to get more throttle out of it!
jimkelly
Apr 1 2008, 07:11 AM
you are one competitive engineer : )
i notice my shifter is bent too (see pic ) : )
that bmw must have really been something : )
* you will not believe how powerful 914v8 is when full throttle range is available to the gas peddle - much more similar to glenn's car than i ever thought it could be.
jim
QUOTE(root @ Mar 31 2008, 07:52 PM)
jim
