New spring queastions, whats your opinion?? |
kojo2001 |
Mar 31 2008, 10:19 PM
Member Group: Members Posts: 88 Joined: 22-June 07 From: california Member No.: 7,832 |
Hi
I need to replace my rear springs and not sure if I should get the 100lb street or 140lb autocross? I will mainly be driving street but some twistys too. What do recommend (IMG:style_emoticons/default/biggrin.gif) |
Dr. Roger |
Mar 31 2008, 10:22 PM
got front and/or rear sway bars?
kojo2001 |
Apr 1 2008, 08:24 AM
got front and/or rear sway bars? Thanks for the responce. I am surprised I only have gotten 1 opinion is my 914 the only one with rear springs??? (IMG:style_emoticons/default/sad.gif) |
jd74914 |
Apr 1 2008, 08:34 AM
We really need more information to help . . .
blitZ |
Apr 1 2008, 08:37 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I believe the rule of thumb is if you increase stiffness on the rear you need to do it on the front. If you don't have at least a stock front sway bar, going to 140lb springs my produce some over steer. Heavier springs will also boot you from stock class in SCCA.
Unfortunately, it's not an easy, straight forward answer. You may want to stick to 100lb springs, unless you are ready to make some additional changes to the front. |
kojo2001 |
Apr 1 2008, 08:39 AM
I believe the rule of thumb is if you increase stiffness on the rear you need to do it on the front. If you don't have at least a stock front sway bar, going to 140lb springs my produce some over steer. Heavier springs will also boot you from stock class in SCCA. Unfortunately, it's not an easy, straight forward answer. You may want to stick to 100lb springs, unless you are ready to make some additional changes to the front. Thanks (IMG:style_emoticons/default/smile.gif) |
Apr 1 2008, 09:16 AM
You want "an answer"? 100 lbs.
You want a "correct" answer? We need more info about your suspension setup. Particularly, what if any sway bars do you have? --DD |
purple |
Apr 1 2008, 10:33 AM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
I have 140 lb springs on new bilsteins and have removed my rear swaybar.
I did this because it was WAAAAY to ass-happy otherwise. removing the rear bar made the back end stay behind the front a lot better. I have front sways though. stock torsion bars and factory sway. green bilsteins up front. i like the setup, drives really nice and comfortable, much more so than my 07 MINI cooper on H&R springs |
rjames |
Apr 1 2008, 10:59 AM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I'm interested in this topic too. Would 140lbs springs be too stiff for a car with a stock sway bar?
purple |
Apr 1 2008, 01:14 PM
Lo-Fi Version | Time is now: 20th May 2024 - 10:25 PM |
