Gas Cap Gaskets, What are these? |
914Sixer |
Apr 1 2008, 07:56 PM
I ordered 10 new gaskets from Porsche 914.201.227.10. I wathed from them to com out of Germany. What they sent matches NOTHING I have I have ever seen before.
1st picture of gasket other pictures of new gasket in early and late gas cap Attached image(s) |
scotty |
Apr 1 2008, 10:33 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
They go on the filler neck of a late '74+ plastic expansion tank (not the cap).
purple |
Apr 2 2008, 06:42 AM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
I ordered the same exact thing. the gasket is usuaally rotted around the filler neck on the expansion chamber. you just run a screwdriver around the neck and it'll crumble off...
kconway |
Apr 2 2008, 06:54 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Mark,
I need one of those if you want to unload one. Kev |
purple |
Apr 2 2008, 10:40 AM
I think the purpose of these is so that when you screw the cap down tight, that it doesnt take channel locks to get it back off. that's what was going on with mine.
Demick |
Apr 2 2008, 11:18 AM
Yep, fits the filler neck on '74+ cars. I bought one years ago. I had to shave down the ID (make the hole in the gasket bigger) to get it to fit. If yours doesn't quite fit, don't force it or it will break. Use sandpaper or a dremmel with a sanding drum to make the hole a little bigger.
Demick |
914Sixer |
Apr 2 2008, 12:06 PM
Yes, everybody is correct. I went up in tha attic and found a late gas tank and they fit perfectly on them. What was throwing me was the one on the tank neck was red and it was stuck to the top. It looked like it was made onto the neck. I need the gasket for the early tank cap. I guess I will look around the VW world as they were standard caps on lots of stuff.
Lo-Fi Version | Time is now: 16th May 2024 - 08:34 AM |
