Deep 6s and tubeless tires, Search was helpful, but still unsure... |
Lavanaut |
Apr 2 2008, 12:37 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
Search turned up a fair amount of good info on running tubless tires on early deep 6s, but before I pull the trigger on buying a set, I would reaaaally feel good about getting confirmation on a couple points:
1. Anyone witnessed firsthand that this is a bad or dangerous idea? Since the early (non-J) wheels don't have the tire bead, some people seem to think that there *might* be some risk in running tubless tires on them. Is this pure speculation? 2. I read a post that I can't seem to find now indicating that a special valve stem of some type is required to run tubless tires on the deeps. Is this true, and if so, can anyone provide more info on this (what, where, how much, etc.)? 3. Lastly, it sounds like tires are mounted on the deep 6s from the back of the wheel, and that a "European" tire machine is required. Now I'm getting nervous about taking them to, say, Les Schwab. Would the local Porsche dealer/shop be a better move? Thanks much! (IMG:style_emoticons/default/beerchug.gif) Reid |
horizontally-opposed |
Apr 2 2008, 12:58 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
1. Risk may be real. But I ran tubeless tires on deep sixes for 16 years of hard backroad driving and occasional autocross and one trackday up at your PIR with no problems. That said, I would not *recommend* doing do.
2. That would make sense, as Harvey Weidman does a mod for $20 per wheel to the valve stem area to make them safe for tubeless tires. I just had that done when I refinished my wheels. But my car always used whatever stems were available in the past, sometimes mounted by specialty shops, sometimes by Costco when I worked there in high school and knew the shop guys, and then Big O once in a pinch. So.... 3. Where you go matters less than who does it. They will hate you for your deep sixes due to the dropcenters that deep sixes have. They can make it hard on tire guys, but a good one will be able to do it (though he might need help if you choose R-compound tires). I think Harvey told me he uses 2-3 guys to mount up deep sixes. As usually applies on this board, others may know more than me... Best, pete |
brer |
Apr 2 2008, 01:51 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
there is a truck valve stem that fits them perfectly.
stubby one, tr14? 19? can't remember. They will hate you when mounting them, make sure they agree that the rim wont be damaged, and the tire goes over the rear lip first! Put diapers on the mounting machine clamp as it is clamped on that purty lip. good luck (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 10:46 AM |
