-6 Engine Compartment, What does yours look like??? |
pek771 |
Apr 5 2008, 05:42 PM
Member Group: Members Posts: 273 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None |
I'm getting the track unit ready. I figured I'd do a little cleanup in the engine bay.
I'm curious as to what everyone's looks like. I'm mostly interested in the structure. I found some welding on the suspension consoles, so I did a bit of extra cutting to investigate further. I'm also wondering if the cage tie-in needs to go all the way to the shock towers? I may need to weld in a small bar on both sides from the cage supports. TIA Pat |
pek771 |
Apr 5 2008, 05:44 PM
pek771 |
Apr 5 2008, 05:46 PM
J P Stein |
Apr 5 2008, 06:00 PM
OK, here's mine.
Attached thumbnail(s) |
J P Stein |
Apr 5 2008, 06:04 PM
Brought the down tubes farther back than yours.
J P Stein |
Apr 5 2008, 06:05 PM
oops, wrong pic
brant |
Apr 5 2008, 06:51 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
looks like some owner may have had a tear or ovaling of the rear swingarm mounting points/console.
very common braces are a very good thing Attached thumbnail(s) |
brant |
Apr 5 2008, 06:53 PM
and
effutuo101 |
Apr 5 2008, 07:46 PM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Here is mine....
effutuo101 |
Apr 5 2008, 07:47 PM
and now for the picture...
Gint |
Apr 5 2008, 09:19 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Mine looks like this... (IMG:style_emoticons/default/smile.gif)
(IMG:http://www.914world.com/members/ginter/DSCN0268.jpg) |
9146FAN |
Apr 5 2008, 09:50 PM
Member Group: Members Posts: 294 Joined: 20-July 04 From: ROSSMOOR, CA Member No.: 2,378 |
Mine looks like this too.
degreeoff |
Apr 5 2008, 09:54 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
well my fav....I liked the reflection off the glass! (IMG:style_emoticons/default/aktion035.gif)
and two.... |
Apr 5 2008, 10:24 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
pek771 |
Apr 6 2008, 10:22 AM
Thanks guys!
JP, that's where I was thinking the cage should have went back to. brant, I'm assuming you have no cage? I like your bracing, but why the Heim joint brace? Pat |
iamchappy |
Apr 6 2008, 10:39 AM
Here's mine, it's kinda crowded in there...
effutuo101 |
Apr 6 2008, 10:42 AM
so pretty. Oh so pretty.
J P Stein |
Apr 6 2008, 10:49 AM
The shock towers become a weak spot when you start jackin' up spring rates....I think the number here is about 250 lbs. Couple that with the poor joint design & welds, tower to long....maybe that's unfair....the car wasn't designed for this..at any rate, it becomes a problem. After running springs in excess of this for a few years I found cracking/failed welds at the bottom juncture, firewall to towers. So, yes, down tubes farther aft is mo better, me thinks. Seal welding everything from the fwd bulkhead to the trans mount is also a good plan.
Don't over look the front end either. Bridging the front & rears together is the best thing I ever did to the chassis...same seal welding. This makes it "a piece." Attached thumbnail(s) |
brant |
Apr 6 2008, 12:52 PM
Thanks guys! brant, I'm assuming you have no cage? I like your bracing, but why the Heim joint brace? Pat Pat, mine runs in a vintage club most vintage clubs and even production classes in other clubs don't allow suspension points to be tied into the cage. so I have a cage, but not allowed to pass through any bulkheads or to any suspension points. all additional bracing (per my rules) must be bolt in, not welded in those heim joints are bolt in aluminum I've got ton's of pictures in THIS THREAD Attached thumbnail(s) |
brant |
Apr 6 2008, 12:54 PM
engine bay:
Lo-Fi Version | Time is now: 18th May 2024 - 06:52 AM |
