-6 Engine Compartment, What does yours look like??? |
GaroldShaffer |
Apr 6 2008, 10:35 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
brant |
Apr 6 2008, 10:42 PM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
garold,
the swing arm mounted console support rods have more clearance on a -4 than on a -6 your going to have to play with the sheet metal likely when we built our -4 we had braces to the dimple on the firewall (similar to yours). When we built the -6 we had to run them straight forward to gain clearance. Especially for valve adjustments. brant |
jaybird840 |
Apr 7 2008, 08:42 AM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
Hey Garold,
Do you have any sketches of your oil routing? I'm starting a six conversion this spring, and will prolly use a roundy-round car oil tank like yours. Any pros/cons/advice would be great. thanks! |
Lo-Fi Version | Time is now: 9th June 2024 - 06:29 AM |
