Damnit: Worlds fastest clutch tube repair |
Dr Evil |
Apr 7 2008, 10:17 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
So I went out to adjust my shifter. It went fine. I was ready to go out and go for a ride....and the clutch pedal goes to the floor (IMG:style_emoticons/default/dry.gif) So I decide to just pull the damn tube as it is already being held in the front end by a conduit clamp (has been doing very well for over 6 years) and it is the fire wall weld that gave up. Pull the tube, braise on a thick washer, reinstall, good to go (IMG:style_emoticons/default/smile.gif) About 1hr.
championgt1 |
Apr 7 2008, 10:19 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Holy (IMG:style_emoticons/default/stromberg.gif) . That is some fast work! (IMG:style_emoticons/default/aktion035.gif)
Trevorg7 |
Apr 7 2008, 10:28 PM
Senior Member Group: Members Posts: 1,242 Joined: 7-December 04 From: Highland Village, TX Member No.: 3,241 Region Association: Southwest Region |
You never cease to amaze Mike.
T |
Dr. Roger |
Apr 7 2008, 11:05 PM
Where's the "This thread is worthless without pics" smilie?
(IMG:style_emoticons/default/biggrin.gif) Good work. I may need this fix someday.... (IMG:style_emoticons/default/driving.gif) |
So.Cal.914 |
Apr 7 2008, 11:09 PM
Apr 7 2008, 11:58 PM
McMark fixed the clutch tube in my car in about 15 minutes. (IMG:style_emoticons/default/smile.gif) Welded, not clamped.
--DD |
ConeDodger |
Apr 8 2008, 01:56 AM
Apex killer! Group: Members Posts: 23,602 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
McMark fixed the clutch tube in my car in about 15 minutes. (IMG:style_emoticons/default/smile.gif) Welded, not clamped. --DD That's nothing. He fixed the fan belt tossing alternator in my car three times in two days and tossed in a carb linkage repair for good measure... Then wrote a how-to and published it here. That burger boy has some mad skillz! (IMG:style_emoticons/default/biggrin.gif) |
Dr Evil |
Apr 8 2008, 06:30 AM
Welding it in the car would have been a bad idea considering the fuel lines are about 1/4 inch from it. That is why I removed and then welded. (IMG:style_emoticons/default/smile.gif)
type47 |
Apr 8 2008, 08:13 AM
well, looks like medical school is good for somethin'....... (IMG:style_emoticons/default/biggrin.gif)
Dr Evil |
Apr 8 2008, 08:37 AM
Ya, but I am not as good as Mark (IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/bootyshake.gif)
Apr 8 2008, 11:41 AM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
McMark fixed the clutch tube in my car in about 15 minutes. (IMG:style_emoticons/default/smile.gif) Welded, not clamped. --DD That's nothing. He fixed the fan belt tossing alternator in my car three times in two days and tossed in a carb linkage repair for good measure... Then wrote a how-to and published it here. That burger boy has some mad skillz! (IMG:style_emoticons/default/biggrin.gif) What was the issue with the alternator tossing fan belts? I have one that refuses to keep a belt on at high RPMS...I have to put it back on after each run at the autox to charge up the battery and I am sick if getting burned... Rich |
Apr 8 2008, 12:05 PM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Welding it in the car would have been a bad idea considering the fuel lines are about 1/4 inch from it. That is why I removed and then welded. (IMG:style_emoticons/default/smile.gif) wuss ... (IMG:style_emoticons/default/biggrin.gif) i just threw a wet rag over the fuel lines and had the fire extinguisher handy (just in case) ... (IMG:style_emoticons/default/rolleyes.gif) Andy |
scotty b |
Apr 8 2008, 09:24 PM
This one time at band camp Mark took his ....oh wait I'm not supposed to tell that one (IMG:style_emoticons/default/unsure.gif) So uh clutch tubes huh.........LOOK IT"S MILES WITH A SQUIRREL !!
ConeDodger |
Apr 8 2008, 10:18 PM
McMark fixed the clutch tube in my car in about 15 minutes. (IMG:style_emoticons/default/smile.gif) Welded, not clamped. --DD That's nothing. He fixed the fan belt tossing alternator in my car three times in two days and tossed in a carb linkage repair for good measure... Then wrote a how-to and published it here. That burger boy has some mad skillz! (IMG:style_emoticons/default/biggrin.gif) What was the issue with the alternator tossing fan belts? I have one that refuses to keep a belt on at high RPMS...I have to put it back on after each run at the autox to charge up the battery and I am sick if getting burned... Rich Rich, There is 'some' adjustment front to rear but in my case, I mounted the pulley on front of the alternator backasswards. Since you are making me pull my pants down in front of everyone. |
Andyrew |
Apr 8 2008, 11:02 PM
I had mine clamped for a year, then I finally did it proper when I thought how tacky (yet effective) the clamps were..
jimtab |
Apr 8 2008, 11:33 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
Welding it in the car would have been a bad idea considering the fuel lines are about 1/4 inch from it. That is why I removed and then welded. (IMG:style_emoticons/default/smile.gif) HaH....no guts no air medal..... |
Andyrew |
Apr 9 2008, 06:23 PM
I welded mine in the car!! Actually I welded from outside of the tunnel; father inside with a fire extinguisher...
Dr Evil |
Apr 10 2008, 09:21 AM
I actually braised, I dont have a welder or the equipment. So, it would have been a MAP flame for prolonged periods of time concomitantly heating my fuel lines and burning all my cables and other stuff.
zymurgist |
Apr 10 2008, 09:28 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Anybody wanna weld my 911 shift rod? I've already replaced it, but I think the old one is repairable.
914werke |
May 14 2008, 12:30 PM
"I got blisters on me fingers" Group: Members Posts: 10,104 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So is there a pictorial "how to repair a broken clutch tube" thread?
I was replacing a cable yesterday installed the new and started adjusting the pedal when TWANG flippin thing ripped free. DOH! (IMG:style_emoticons/default/headbang.gif) Im mean compleatly (IMG:style_emoticons/default/WTF.gif) The Firewall is already ripped, so looks like Im fixing it the WE if I can get some help. Its supposed to run along the Drivers side of the tunnel correct? So if your carefull you should be able to weld wo lighting up the fuel lines (on opposite side) (IMG:style_emoticons/default/confused24.gif) Or do I have to pull the fuel lines? Ive seen quite a few cars where the PO has cut the tunnel up to preform the repair. Is that really necessary? |
Lo-Fi Version | Time is now: 28th May 2024 - 01:43 PM |
