So is there a pictorial "how to repair a broken clutch tube" thread?
I was replacing a cable yesterday installed the new and started adjusting the
pedal when TWANG flippin thing ripped free. DOH!
Im mean compleatly
The Firewall is already ripped, so looks like Im fixing it the WE if I can get some help.
Its supposed to run along the Drivers side of the tunnel correct? So if your carefull you should be able to weld wo lighting up the fuel lines (on opposite side)
Or do I have to pull the fuel lines?
Ive seen quite a few cars where the PO has cut the tunnel up to preform the repair. Is that really necessary?
