Plastic Fuel Lines, DANGER!!! |
ericread |
Apr 9 2008, 07:12 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
As I continue to update my 914, I was getting concerned that the plastic fuel lines in the tunnel could create a danger. Postings here indicate that they can be a serious fire problem to "don't worry, they'll be fine if they're left alone.
I went ahead and purchased the stainless steel fuel lines from CFR and set out to replace the lines on Saturday. After removing all the stuff covering up the tunnel, I inspected the existing plastic fuel lines. To my dismay, they looked pretty good. But, what the heck, I decided to complete the replacement. Once I had puled the old lines out I took another, closer look. When I picked up the plastic line it easily cracked and broke: And, although you can see a couple of breaks here, my finger is pointing to a number of very small cracks that are not very apparent in this picture: The plastic was really brittle and easily cracked. Would it have broken if I had left it alone in the tunnel? Maybe not. But I am really glad I replaced the plastic line when I did. If the fuel line was this brittle in my 74, then I would think that all of the plastic fuel lines are a potential fire hazard. Please take a few minutes to inspect your fuel lines. It may save your car, or even your life. |
ConeDodger |
Apr 9 2008, 10:44 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I did the same. Replaced my EFI plastic lines with a single stainless line for my carbs. My plastic lines looked like new. Not a single sign of wear.
I guess it depends on the car. Glad you replaced yours though. That would have been a heck of a CarBQ! (IMG:style_emoticons/default/blink.gif) |
913B |
Apr 9 2008, 11:52 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Boy I am just taking my chances on my 71. Makes me re-think this necessary upgrade. Did you have the engine out of the car ?
Ted |
PeeGreen 914 |
Apr 10 2008, 12:02 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
It is very easy to do. You do not need to pull the engine or gas tank at all.
Trevorg7 |
Apr 10 2008, 12:13 AM
Senior Member Group: Members Posts: 1,242 Joined: 7-December 04 From: Highland Village, TX Member No.: 3,241 Region Association: Southwest Region |
Cap'n Krusty |
Apr 10 2008, 12:35 AM
I may be clueless, but I fail to see how the lines through the tunnel can be changed with the fuel tank installed. May be just me, and maybe 35 years of working professionally on 914s isn't enough experience, but I don't think it can be done.
The Cap'n, always ready to learn new stuff ............................ |
PeeGreen 914 |
Apr 10 2008, 12:39 AM
uhhh.. I was smoking crack... sorry Cap'n... yeah. I removed the tank. I don't know what I was thinking. However, it is very easy.
ericread |
Apr 10 2008, 01:15 AM
Boy I am just taking my chances on my 71. Makes me re-think this necessary upgrade. Did you have the engine out of the car ? Ted I had asked around on this forum and everyone assured me that this did not necessitate removing the engine. Sure as sh*t, it took a couple of hours to replace the lines and the engine was never in the way. The hardest part was getting the rubber caps off the firewalls and removing the items over the tunnel. I had removed the fuel tank once before, so it really wasn't difficult. Just make sure your tank is empty... Please note that the rubber grommets at the engine firewall disintegrated when I removed the old lines. I was able to get new grommets with a pretty good match at Kragens for a couple of bucks each. The rubber seal into the fuel tank area is a b*tch to remove, but once off, it goes back on pretty easily. All in all, a couple of hours and you have new stainless steel fuel lines. I used the lines from CFR/Tangerine and had no difficulties whatsoever. (no affiliation). Good luck! |
thesey914 |
Apr 10 2008, 02:24 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
I recently replaced mine and wish I'd left them they were fine and I was only using one for carbs -no return. The length past the firewall had hardened but was still serviceable.
Once they were out I tested them to see how brittle they were on the tunnel section and I had to flex them 5 or 6 times 180 deg to get them to crack. Not sure they even split but they were kinked beyond re-using. Modern cars still use plastic fuel lines. Good idea to check them but don't my not necessarily have to bin them |
rhodyguy |
Apr 10 2008, 08:51 AM
the plastic fuel lines in the tunnel terminate at the large rectangular rubber block in the front firewall. the 2 short metal lines incased in the block need to be removed to run the ss lines thru to the area under the tank. when inserting the ss line(s), a little glycerin on the outside of the line allows it to slide right thru. it could be done with the tank in but you need little hands to renew the rubber lines from the tank to the ss hard lines and any remaining fuel is going to drain all over your hands and face. if you haven't cleaned the inside of your tank, you need to pull it anyway.
ClayPerrine |
Apr 10 2008, 08:58 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
<soapbox> I have been preaching this for YEARS. After watching Betty's car burn, I will never own a 914 that doesn't have the plastic lines replaced. It is cheap insurance. </soapbox> (IMG:style_emoticons/default/agree.gif) |
ericread |
Apr 10 2008, 09:22 AM
the plastic fuel lines in the tunnel terminate at the large rectangular rubber block in the front firewall. the 2 short metal lines incased in the block need to be removed to run the ss lines thru to the area under the tank. when inserting the ss line(s), a little glycerin on the outside of the line allows it to slide right thru. it could be done with the tank in but you need little hands to renew the rubber lines from the tank to the ss hard lines and any remaining fuel is going to drain all over your hands and face. if you haven't cleaned the inside of your tank, you need to pull it anyway. Glycerin! Dammit! That would probably have saved me hours!!! (IMG:style_emoticons/default/headbang.gif) |
zymurgist |
Apr 10 2008, 09:27 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
the plastic fuel lines in the tunnel terminate at the large rectangular rubber block in the front firewall. the 2 short metal lines incased in the block need to be removed to run the ss lines thru to the area under the tank. when inserting the ss line(s), a little glycerin on the outside of the line allows it to slide right thru. it could be done with the tank in but you need little hands to renew the rubber lines from the tank to the ss hard lines and any remaining fuel is going to drain all over your hands and face. if you haven't cleaned the inside of your tank, you need to pull it anyway. Glycerin! Dammit! That would probably have saved me hours!!! (IMG:style_emoticons/default/headbang.gif) I use dish soap. Works well and you probably already have some in the house. |
ChrisFoley |
Apr 10 2008, 10:06 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Even if you already had metal lines in the car when you bought it, don't assume they are safe without inspecting them. What we found in Lee Auerbach's car was 5/16" brake line coming through the firewall, and the original steel section from the factory lines up front. Unfortunately, they were joined inside the tunnel by a short hose and cheap hose clamps. Without any reason to inspect the lines inside the tunnel, it would have remained that way and the hose connection would have eventually leaked. If Lee had asked us to retrofit the engine with D-jet the supply side connection would have failed quickly I am sure.
ericread |
Apr 10 2008, 10:50 AM
Even if you already had metal lines in the car when you bought it, don't assume they are safe without inspecting them. What we found in Lee Auerbach's car was 5/16" brake line coming through the firewall, and the original steel section from the factory lines up front. Unfortunately, they were joined inside the tunnel by a short hose and cheap hose clamps. Without any reason to inspect the lines inside the tunnel, it would have remained that way and the hose connection would have eventually leaked. If Lee had asked us to retrofit the engine with D-jet the supply side connection would have failed quickly I am sure. I agree. One of the points I was trying to make is that although the plastic tubing looked OK while it sat in the tunnel, once the line was removed I found that it was pretty ripe to fail. This could have been the same with non-plastic tubing. Another "Truth" that has previously bitten me is that although a part may have been recently replaced, the PO may very well have installed it incorrectly, used the incorrect part, or even worked to hide the actual problem. I look at it this way - It's my car and I am responsible not only for the safety of myself and my passengers, but I have a responsibility to ensure this car makes it through to the next generation. As these cars become more scarce, it is important that these amazing little vehicles stay on the road. It's part of our automotive history, which is sadly being neglected outside of a few groups like this one. (IMG:style_emoticons/default/beerchug.gif) |
VaccaRabite |
Apr 10 2008, 11:20 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
When you buy a 914, ALL the fuel lines should be replaced.
On mine, the lines in the engine bay were cracked. The tunnel lines were brittle. It was a fire waiting to happen. Your PO may have put new lines in, or your lines may be 30 years old. As someone said, it is cheap insurance. Zach |
6freak |
Apr 15 2008, 03:56 PM
It is very easy to do. You do not need to pull the engine or gas tank at all. Jon i cant find that forums or bolg with all the northwest guys on it ...help (IMG:style_emoticons/default/headbang.gif) |
auerbach |
Apr 15 2008, 11:07 PM
Lee David Auerbach, Esq Group: Members Posts: 235 Joined: 26-July 07 From: Westchester, New York Member No.: 7,947 Region Association: MidAtlantic Region |
Boy its a good thing that I didn't ask Chris to retro with D-Jets, my wife would have been spending the life insurance money -- well that was unless SHE was driving. (IMG:style_emoticons/default/biggrin.gif)
Cevan |
Apr 16 2008, 06:50 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
For me it was peace of mind. I replaced all the fuel lines from the tank back. I had to replace at least half the clamps because they were not FI clamps. The last thing I want is a car fire while taking my 5 year old to school.
Here we are this morning. It's 35 degrees out so I was a good father and put the top on. |
Mark Henry |
Apr 16 2008, 10:44 AM
If the teen is unmolessted and in pristine orginial condition plus the lines are still clear in colour then they are fine if they pass inspection.
If they look like those, the car is butchered, front pump mod, etc. then they should be gone through. The rubber hose should be replaced every 5yrs or so. FI clamps and hose only. I still have my clear lines and they have no issues, but my car is in good shape. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:11 PM |
