Targa top front seal 914-563-319-10 $30 |
Mikey914 |
Apr 16 2008, 12:43 AM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is the one that goes under the coveted upper and side seals. It hides under that seal. Its where nose of the targa top slides into and provides an additional barrier.
Well after the 3rd try we finally got it right, took some re-tooling on the die to make it right, but the lower lip suck up against the edge nicely. I did not realize how bad mine really was until I removed it! Note you will need to take an sharp scissors or exacto knife to cut the notch for the center. It's just in the fin not all the way through. I used my old one as a guide, it took me about 2 minutes. $30 Thanks to all for your support. Attached image(s) |
pavpav12 |
Apr 16 2008, 05:03 AM
Newbie Group: Members Posts: 27 Joined: 20-April 07 From: mountaintop, pa Member No.: 7,680 Region Association: North East States |
I need one
rfuerst911sc |
Apr 16 2008, 06:43 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I'd buy one.
jsayre914 |
Apr 16 2008, 09:59 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
i need one (IMG:style_emoticons/default/rolleyes.gif)
db9146 |
Apr 21 2008, 09:58 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I'm in.
tango-52 |
Apr 21 2008, 10:45 AM
Member Group: Members Posts: 149 Joined: 18-October 07 From: San Diego County Member No.: 8,243 Region Association: Southern California |
Put me down for two.
pavpav12 |
Apr 21 2008, 11:45 AM
i need one
Howie's 914 |
Apr 21 2008, 04:49 PM
Member Group: Members Posts: 76 Joined: 29-June 04 From: Greensboro, NC Member No.: 2,273 |
You know I need one.
FourBlades |
Apr 23 2008, 06:59 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
budman5201 |
Apr 23 2008, 09:00 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
I'll take one too!
scotty b |
Apr 27 2008, 09:56 AM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
(IMG:style_emoticons/default/biggrin.gif) So about a complete rubber kit ....................... (IMG:style_emoticons/default/popcorn[1].gif) |
Mikey914 |
May 16 2008, 01:28 AM
Well having some fun with this one. First run the pins on the dies bumped out and gave inconsistencies in the wall thickness. The 1st picture shows this well. The run today the wall thickness was consistent, but the gap opened up where the end connects to the inside of the windshield frame. We will be able to do another proving run this next week. I think with some tweaking to the die we will have this one ready to run. I know that I had hoped to have the first article this week, but we should have it 100% this next Wednesday.
Just a progress report. Will be able about 1 week after the proving run (28th-29th). This is when the outer door seals are coming off the other press, so lots happening last week of May. Attached image(s) |
rhodyguy |
May 16 2008, 09:45 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
nice. can you make a inner dash to windshield seal that works? that one has a metal channel type affair incased that sort of grips the edge. i don't know how you'd get around that.
Mikey914 |
May 16 2008, 10:18 AM
Thanks, I'm actually working on the inner windshield seal. I'm at the place where I'm waiting for a sample of the OEM seal. None of my cars have the windshield out right now. SO, if you or anyone has a small section you could send me I will need a Beta tester.
Thanks, Mark |
Mikey914 |
May 23 2008, 08:31 PM
Updated with installed pictures. You can see the difference of the thickness of the walls and how they are more uniform now. That double hollow was a PITA !!!
Tried it out, Mine fits perfectly! (Pictures at first posting) Attached image(s) |
Mikey914 |
Aug 22 2008, 02:41 PM
PRICE REDUCED, need to move some of these to pay for some new tooling.
$28 each |
Lo-Fi Version | Time is now: 9th May 2024 - 03:41 PM |
