Targa top front seal 914-563-319-10 $30 |
Mikey914 |
Apr 16 2008, 12:43 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is the one that goes under the coveted upper and side seals. It hides under that seal. Its where nose of the targa top slides into and provides an additional barrier.
Well after the 3rd try we finally got it right, took some re-tooling on the die to make it right, but the lower lip suck up against the edge nicely. I did not realize how bad mine really was until I removed it! Note you will need to take an sharp scissors or exacto knife to cut the notch for the center. It's just in the fin not all the way through. I used my old one as a guide, it took me about 2 minutes. $30 Thanks to all for your support. Attached image(s) |
Mikey914 |
May 16 2008, 01:28 AM
Well having some fun with this one. First run the pins on the dies bumped out and gave inconsistencies in the wall thickness. The 1st picture shows this well. The run today the wall thickness was consistent, but the gap opened up where the end connects to the inside of the windshield frame. We will be able to do another proving run this next week. I think with some tweaking to the die we will have this one ready to run. I know that I had hoped to have the first article this week, but we should have it 100% this next Wednesday.
Just a progress report. Will be able about 1 week after the proving run (28th-29th). This is when the outer door seals are coming off the other press, so lots happening last week of May. Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 06:49 AM |
