Targa top front seal 914-563-319-10 $30 |
Mikey914 |
Apr 16 2008, 12:43 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is the one that goes under the coveted upper and side seals. It hides under that seal. Its where nose of the targa top slides into and provides an additional barrier.
Well after the 3rd try we finally got it right, took some re-tooling on the die to make it right, but the lower lip suck up against the edge nicely. I did not realize how bad mine really was until I removed it! Note you will need to take an sharp scissors or exacto knife to cut the notch for the center. It's just in the fin not all the way through. I used my old one as a guide, it took me about 2 minutes. $30 Thanks to all for your support. Attached image(s) |
Mikey914 |
May 23 2008, 08:31 PM
Updated with installed pictures. You can see the difference of the thickness of the walls and how they are more uniform now. That double hollow was a PITA !!!
Tried it out, Mine fits perfectly! (Pictures at first posting) Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 10:40 AM |
