Wiring Help - See Pic |
vesnyder |
Apr 16 2008, 06:40 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
This is the harness that has the three prong plug that plugs into the board on the front left side of the engine compartment. It is the red wire that I do not know where to connect? They are part of the same harness that originates at the alternator. I thought it went to the battery but if does not seem long enough?
Attached thumbnail(s) |
JeffBowlsby |
Apr 16 2008, 06:44 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The thick red cable goes between the ALT and the lug on the starter shared with teh battery + cable. (IMG:style_emoticons/default/biggrin.gif)
vesnyder |
Apr 16 2008, 07:42 PM
That makes sense! I figured it had to get back to the battery + terminal but was not long enough to attach directly.
Gracias! The thick red cable goes between the ALT and the lug on the starter shared with teh battery + cable. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:53 PM |
