carb adjustment? |
carb adjustment? |
JOE M |
Apr 17 2008, 11:54 AM
Member Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
I have dual redline webber carbs on my 72` 914. First there is an ir line going to carb but nothing going to the second carb. Should there be a hose going to each carb? What is the best way for adjustment. I did go to the redline web page but it does not really say how to setup both carbs. Do I get one set and than go to the second or should I do them together? I have never done this. If you look at the attached picture you can see a clear hose on the right but nothing on the other carb.
Lo-Fi Version | Time is now: 17th May 2024 - 03:01 PM |
