New Development, Possible VIN sticker replacement for door jam |
Gint |
Apr 18 2008, 10:34 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I need one if it's done right.
And BTW the WS pillar tag isn't permanent. It's riveted on. |
burton73 |
Apr 18 2008, 11:40 AM
burton73 Group: Members Posts: 3,549 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Rick—I am using a new MacBook Air
When I took my 6 on the trailer with the PO to the DMV in Los Angeles they came out and looked at the window and then when we could not see the door because the trailer was in the way, they said the 2nd VIN was on the body. They would not put it in my name or give me a clear title without seeing 2 out of 3 VINs. They had a book that told them where the VINs where. Every one will want one if done right as it is the finishing touch. I remember how nice the one was on my 72 beetle in my favorite blue. Is it just the sliver ones that have the safety circles? Bob |
Cevan |
Apr 18 2008, 12:28 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Regardless of anything else, this issue, if you're in the unlucky situation to have it questioned by the authorities, will come down to the attitude of the officials involved. Some would let it slide/ignore it/think nothing is wrong. Some would throw the book at you. And if they do throw the book, then a friendly conversation is not going to change it. A LONG legal battle would be necessary to clear it up. And in the mean time, your car will be impounded and even could be crushed. I'm not sure that would happen, unless you are changing the VIN#. At least not in my state. |
rick 918-S |
Apr 19 2008, 08:58 AM
Hey nice rack! -Celette Group: Members Posts: 20,489 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Regardless of anything else, this issue, if you're in the unlucky situation to have it questioned by the authorities, will come down to the attitude of the officials involved. Some would let it slide/ignore it/think nothing is wrong. Some would throw the book at you. And if they do throw the book, then a friendly conversation is not going to change it. A LONG legal battle would be necessary to clear it up. And in the mean time, your car will be impounded and even could be crushed. I'm not sure that would happen, unless you are changing the VIN#. At least not in my state. Yes, I have a Dell...? Anywho... I'm back home now. Ok, My position is the same. First, yes the stamped tag is riveted to the pillar, but you must remove the glass to get it out. Pretty safe bet. Second , they could check the stamping on the right top of the front inner wheel house. You can't change that one without some serious work. (unless someone cut your front end off and sectioned it onto another one.. (IMG:style_emoticons/default/dry.gif) ) And the key here is it must match the stamping or what's the point of sticking it on the car? I agree the DMV has a resource for locations of the vin. But it's not a picture book. If the number matched I doubt they would look any further. |
jaminM3 |
Apr 19 2008, 08:13 PM
Member Group: Members Posts: 418 Joined: 23-March 07 From: SLC, UT Member No.: 7,619 Region Association: Intermountain Region |
Here are some examples of original stickers for /4.
Are the dots at the beginning and end different on every sticker? Attached image(s) |
rick 918-S |
Apr 20 2008, 09:19 AM
you can really see the punch out circles on this one.
BTW: this car was originally WHITE. WHITE CAR: Attached image(s) |
burton73 |
Apr 20 2008, 09:28 AM
What size do you think the circles are in mm? A guess.
The black sticker does show it well. My 86 Carrera has no circles on its black sticker. Bob |
Lo-Fi Version | Time is now: 8th June 2024 - 03:46 AM |
