Battery tray pedestal, What are these holes for? |
watsonrx13 |
May 3 2008, 07:07 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
OK, I've removed the old battery tray/pedestal, both had either either pop-riveted or sheet metal screws to hold them.. Anyway, I welded up the extraneous holes, but what are these small holes in the front for? Also, what's the purpose of the large holes on the sides? (RD design). BTW, the pic is from my current driver, not the car I'm working on this weekend.
Also, do I need to remove the paint that is on the battery tray/pedestal? Or can I just scuff it and repaint? -- Rob |
ericread |
May 3 2008, 07:56 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
The small holes are there as starter points for rust. That's how you know they're authentic! (IMG:style_emoticons/default/biggrin.gif)
Eric_Shea |
May 3 2008, 08:02 PM
sixnotfour |
May 3 2008, 08:06 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
and dual relay
J P Stein |
May 3 2008, 09:23 PM
1) to let the acid in
or 2) to let the acid out |
Joe Bob |
May 3 2008, 09:25 PM
Speed holes....
iamchappy |
May 3 2008, 09:28 PM
Generally i have found that paint does not adhere well to the rust colored primer parts i have seen in the past, i would sand it well or off, then reprime and paint.
So.Cal.914 |
May 3 2008, 09:49 PM
KELTY360 |
May 3 2008, 11:20 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) Looks like a rust-breasted warbler to me. |
So.Cal.914 |
May 3 2008, 11:43 PM
watsonrx13 |
May 4 2008, 09:13 AM
and dual relay Thanks guys. Which year/engine used the dual relay and/or resitor block? I have a '74 2.0l with the original FI and didn't have either of these, so I was going to weld up these holes... In regards to the paint, thanks for the suggestions. I'll definately give the paint a good scratching before I prime/paint it... Bird house, that's a good one... (IMG:style_emoticons/default/av-943.gif) -- Rob |
Eric_Shea |
May 4 2008, 09:16 AM
QUOTE Thanks guys. Which year/engine used the dual relay and/or resitor block? I have a '74 2.0l with the original FI and didn't have either of these, so I was going to weld up these holes... (IMG:style_emoticons/default/confused24.gif) If I recall, I had a 74 1.8 that had it. |
SLITS |
May 4 2008, 09:25 AM
In the original design, the larger hole was for an engine compartment light. After many attempts at making it work, the Krauts figured out the if they mounted the battery high enough for the light to work, the engine lid wouldn't close.
Then they decided to put a burner in there to cook Bratwurst. Unfoutunately they found out that the battery sitting on top of the bratwurst squeezed all the goodness out. Disgusted, they went back to drinking and forgot to change the fabrication details. |
Allan |
May 4 2008, 09:31 AM
On my '75 that's where my rev limiter was attached.
swl |
May 4 2008, 09:47 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
So.Cal.914 |
May 4 2008, 10:05 AM
QUOTE Then they decided to put a burner in there to cook Bratwurst. I can see that... (IMG:style_emoticons/default/rolleyes.gif) |
Cevan |
May 4 2008, 01:49 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Lo-Fi Version | Time is now: 18th May 2024 - 11:13 AM |
