Bolt Stripped - Front End Adjuster - I have an idea?!?, Can I do this? |
Wanna9146 |
May 3 2008, 09:02 PM
Member Group: Members Posts: 235 Joined: 19-January 08 From: Florida Member No.: 8,595 Region Association: South East States |
One of my front end adjuster bolts is stripped and it ain't coming out. I tried every trick that I read after searching the forum.
I was about to drop the front end so I can attack the bolt from a different angle when I thought about removing the adjuster cap (torsion bar cap). Can I just pry this cap off with the bolt in place? Is the cap under tension from the torsion bar if the front end is off the ground? (IMG:style_emoticons/default/idea.gif) |
sww914 |
May 3 2008, 09:49 PM
There's no tension on it when the car's off of the ground. It must slide a long way off of the end of the torsion bar and the bolt interferes with the X member like it was designed to. You can cut the bolt off near the torsion bar cap, slide the cap off and work on it in a vice. It is a special bolt but a normal bolt will work in a pinch if you can't find the right one right away.
Wanna9146 |
May 3 2008, 09:52 PM
I already have new caps and/or bolts ready to go. Just wondering if I can pop the cap off without "unloading" the torsion bar first. I think I'll be able to slice the bolt flush...
There's no tension on it when the car's off of the ground. It must slide a long way off of the end of the torsion bar and the bolt interferes with the X member like it was designed to. You can cut the bolt off near the torsion bar cap, slide the cap off and work on it in a vice. It is a special bolt but a normal bolt will work in a pinch if you can't find the right one right away. |
rhodyguy |
May 4 2008, 08:21 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if you have the tire off of the ground and trim the screw, the adj arm should come off. if it's rusted on the torsion bar may come with it. no big deal.
k |
Wanna9146 |
May 4 2008, 09:49 AM
I've never had the suspension/torsion bars apart before...I only know what I've read in the manuals, so not sure what to expect. I picture an explosion of some sort like when I took my father's wristwatch apart many years ago.
if you have the tire off of the ground and trim the screw, the adj arm should come off. if it's rusted on the torsion bar may come with it. no big deal. k |
rhodyguy |
May 4 2008, 10:06 AM
it won't be under load. no explosion. if the tbar somes out check the condition of the little foam doughnut gasket. speaking of manuals...the detail in the haynes re changing a front strut cartridge is pretty funny. tearing the whole damn thing apart...wth!! haha.
k |
Wanna9146 |
May 6 2008, 11:35 PM
Well...I did it without dropping the front end or having to remove the adjuster, thanks to a Craftsman Bolt-Out...
(IMG:http://public.vuquoc.com/bolt-out.png) Hammered that sucker on to the bolt head and presto! Bolt out... |
dflesburg |
May 7 2008, 12:19 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
The great pumpkin had allen head bolts and they were locked up. Finally got one out after welding in a piece of allen... The other side got cut out with a cut off wheel once the cap was off the car it was easier to get a good weld on the allen and it came out easy.. ( I hate welding straight up and burning my bald spot... )
Lo-Fi Version | Time is now: 24th May 2024 - 07:58 PM |
