One of my front end adjuster bolts is stripped and it ain't coming out. I tried every trick that I read after searching the forum.
I was about to drop the front end so I can attack the bolt from a different angle when I thought about removing the adjuster cap (torsion bar cap). Can I just pry this cap off with the bolt in place? Is the cap under tension from the torsion bar if the front end is off the ground?
