DAQ - Where does the starter ground cable from the battery go |
Gint |
May 3 2008, 09:07 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Where in the hell does this stupid ground cable from the battery go down around the starter? I need a picture please.
ConeDodger |
May 3 2008, 09:09 PM
Apex killer! Group: Members Posts: 23,589 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Where in the hell does this stupid ground cable from the battery go down around the starter? I need a picture please. Mike, I am not sure if I understand you but on my car the ground side of the battery goes to the chassis just above the battery. The hot side goes to the starter. |
Joe Bob |
Ummm, sorry no pic my ride is up at Krusty's. Should bolt to a ground on the body inside the engine bay.....
But the cable from the battery TO the starter is RED and HOT.... |
Gint |
May 3 2008, 09:10 PM
Duh... It's the hot cable not a ground. Thanks.
jasons |
May 3 2008, 10:14 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Does this help?
Gint |
May 3 2008, 10:30 PM
Not really because I already got it. Rob triggered the right brain cell . It's alive!
But thanks for posting that. It's a great picture! |
type47 |
May 4 2008, 06:45 AM
Does this help? only if you wheel it over to my house and put it in my car! (IMG:style_emoticons/default/rolleyes.gif) nice looking powertrain! (IMG:style_emoticons/default/pray.gif) |
swl |
May 4 2008, 06:57 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Jason, what muffler is that. Have one but no idea what it is.
jasons |
May 4 2008, 10:13 AM
The pic isn't mine. Just one I saved. The muffler looks like a bursch.
stateofidleness |
May 4 2008, 10:15 AM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
damn, is there a larger version, or higher res version of that pic anywhere?
somethin similar? i love collecting pics like that for when I go to replace all the lines and hoses |
So.Cal.914 |
May 4 2008, 10:16 AM
rhodyguy |
May 4 2008, 10:26 AM
how's this one mike? the ground cable from the battery attaches to the stud located on the chassis just forward of the battery. (IMG:style_emoticons/default/wacko.gif)
k Attached image(s) |
Gint |
May 4 2008, 10:58 AM
Not really because I already got it. Rob triggered the right brain cell . It's alive! But thanks for posting that. It's a great picture! Long day huh. Kevin, great shot. I was thinking the battery cable to the starter was a ground instead pf power. I had the car on the lift and I was underneath it and just not even thinking. As Paul said, it was a long day. When Rob posted I finally woke up and realized that it was a hot wire and not a ground. If I'd lowered the lift and looked at the battery end of the cable I would have realized that before posting this thread. Even though I have a Ford relay attached to the starter, at that point there was really only one place it (the cable) could go on the starter. I got it started last night around 8:30, but it will need some tuning today. I put thinner manifold gaskets on it so I had to shorten the linkage rod too. I still need to replace my front shift rod and get the rear shift rod installed also. At the moment I can't find neutral (which is really stupid I know), but this is an unknown transaxle (swapped out the worn 2nd synchro unit for this one). |
rhodyguy |
May 4 2008, 11:05 AM
did you leave the rear shift rod out prior to installing the engine? (IMG:style_emoticons/default/chair.gif)
also, i don't understand the probs you guys are have with the intake studs. phenolic gasket, cb tall, flat washer, cv joint locking washer, nut. it all fits. the one pictured isn't torquered down yet. what's the deal? k Attached image(s) |
Gint |
May 4 2008, 11:08 AM
Of course. (IMG:style_emoticons/default/confused24.gif) I'm shifting it at the shift console on the transaxle. I got and verified first, and reverse, but neutral is nowhere to be found.
TROJANMAN |
May 4 2008, 11:17 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Neutral is overrated
rhodyguy |
it's a pain fishing the damn rod thru the bar and what not after the fact. neutral is right inbetween 1st and 2nd. (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 02:24 PM |
