QUOTE(So.Cal.914 @ May 4 2008, 09:16 AM)
QUOTE(Gint @ May 3 2008, 09:30 PM)
Not really because I already got it. Rob triggered the right brain cell . It's alive!
But thanks for posting that. It's a great picture!
Long day huh.
Yes. Too many of them.
Kevin, great shot.
I was thinking the battery cable to the starter was a ground instead pf power. I had the car on the lift and I was underneath it and just not even thinking. As Paul said, it was a long day. When Rob posted I finally woke up and realized that it was a hot wire and not a ground. If I'd lowered the lift and looked at the battery end of the cable I would have realized that before posting this thread. Even though I have a Ford relay attached to the starter, at that point there was really only one place it (the cable) could go on the starter.
I got it started last night around 8:30, but it will need some tuning today. I put thinner manifold gaskets on it so I had to shorten the linkage rod too. I still need to replace my front shift rod and get the rear shift rod installed also. At the moment I can't find neutral (which is really stupid I know), but this is an unknown transaxle (swapped out the worn 2nd synchro unit for this one).
