muffler design with cat converter, anyone got one?? |
jimkelly |
May 4 2008, 03:35 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i barely got thru emissions last time
would be nice for the club to have a loaner muffler/cat that we can use to get thru emissions testing then afterwards reinstall our muffler back on jim |
drive-ability |
May 4 2008, 06:23 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
i barely got thru emissions last time would be nice for the club to have a loaner muffler/cat that we can use to get thru emissions testing then afterwards reinstall our muffler back on jim Jim, I haven't had to smog my car in Ca. (YET) so if I did I would just put on two cats (or one for single exhaust) and then see how it sounds. If its too loud slide on a muffler when you get to the shop. Let it stick out, the smog guy won't or shouldn't get in the way of that.. emissions are his concern anyway mufflers surely aren't... |
jimkelly |
May 4 2008, 08:19 PM
i am talking about my v8 car and my 2.0 car.
i have thought of putting a small gas tank in the trunk with iots own fuel pump, so that i can run a gas/alcohol mixture - just for emissions inspection purposes. jim |
drive-ability |
May 4 2008, 10:44 PM
i am talking about my v8 car and my 2.0 car. i have thought of putting a small gas tank in the trunk with iots own fuel pump, so that i can run a gas/alcohol mixture - just for emissions inspection purposes. jim I guess it depends how much you need to improve the levels. In most states you have to test the timing, how can your V8 car have this done??? Retarding the timing will reduce the hydrocarbons and leaning it out will reduce the CO but increase the hydrocarbons so its a balancing act. I've herd of using different fuels but a big NEW cat will clean up almost anything for a short time. I had a twin turbo rotary RX7 that was ported and ran hard. I got a cheep fuel tuner and leaned out the mixture along with adding a large cat converter. It ran just enough to get there and do the smog test. It passed and the smog tech was shocked!! Google it maybe you will get some good ideas.. Jim in your blog I noticed the 914 using the front wheel drive auto and a straight axle rear end, wow that looks interesting... Is there anymore picks and information ?? |
JeffBowlsby |
May 4 2008, 11:55 PM
914 Wiring Harnesses Group: Members Posts: 8,517 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Wouldn't you guys just sleep better if you made what changes you needed to do to pass and left them in place? Beats having to do the dance every couple of years and you would be able to have a clear conscience...
Integrity is gud...(IMG:style_emoticons/default/biggrin.gif) |
drive-ability |
May 5 2008, 07:34 AM
Wouldn't you guys just sleep better if you made what changes you needed to do to pass and left them in place? Beats having to do the dance every couple of years and you would be able to have a clear conscience... Integrity is gud...(IMG:style_emoticons/default/biggrin.gif) In Ca. we don't need Integrity for 1975 and older cars (IMG:style_emoticons/default/shades.gif) , Where Jim lives it seem to be needed once every 2 years or so (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 07:08 AM |
