| gollygwagen |
Oct 18 2012, 08:52 AM
Member ![]() ![]() Group: Members Posts: 88 Joined: 13-August 12 From: Highlands Ranch, CO Member No.: 14,799 Region Association: None |
BTW... the perfect 914 (IHMO) 911RSR front suspension. Boxster S brakes. Boxster rear suspension. Boxster transmission. VW W12 motor. The W12 will bolt up to a boxster transmission with no adapters. And it is shorter than a Porsche six. Can you say "914-12"???? That's funny, I just posted the same engine. I love it, but out of my budget range. Can you imagine the sound? |
| ScoopLV |
Oct 19 2012, 01:04 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 545 Joined: 7-September 12 From: Las Vegas Member No.: 14,897 Region Association: Southwest Region |
Totally doable. I've got a close friend in Minneapolis with a W12 FWD GOL. Pulls mid 10s in the quarter. The same package should fit nicely in a teener. Pricey, but it'll work. While we're at it, let's install a couple JATO rocket boosters, and pressurize the cabin for lift-off. I'll bet we can get a deal on ceramic tiles from a mothballed space shuttle for re-entry. |
| gollygwagen |
Oct 19 2012, 08:03 AM
While we're at it, let's install a couple JATO rocket boosters, and pressurize the cabin for lift-off. I'll bet we can get a deal on ceramic tiles from a mothballed space shuttle for re-entry. Heck yeah, NASA isn't using them. Only seems right if I'm doing NASA TT events! (IMG:style_emoticons/default/smilie_pokal.gif) |
| 76-914 |
Oct 19 2012, 01:23 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Totally doable. I've got a close friend in Minneapolis with a W12 FWD GOL. Pulls mid 10s in the quarter. The same package should fit nicely in a teener. Pricey, but it'll work. While we're at it, let's install a couple JATO rocket boosters, and pressurize the cabin for lift-off. I'll bet we can get a deal on ceramic tiles from a mothballed space shuttle for re-entry. That would be RATO (rocket assist). JATO = jet assist take off. Did any of you ever read the Darwin Award's for the guy that strapped on a couple of RATO's to a 64 Impala? |
| polo classic |
Oct 19 2012, 02:07 PM
Newbie ![]() Group: Members Posts: 32 Joined: 7-October 11 From: Oslo Member No.: 13,650 Region Association: Scandinavia |
I did some measurements of a Boxster up on a lift to see if the whole rear suspension would fit under a 914. It will... but you could not do it without flares. And it is one of my long term goals. BTW... the perfect 914 (IHMO) 911RSR front suspension. Boxster S brakes. Boxster rear suspension. Boxster transmission. VW W12 motor. The W12 will bolt up to a boxster transmission with no adapters. And it is shorter than a Porsche six. Can you say "914-12"???? There's a school in Sweden that has made a 014 on a Boxster chassie.... If the W12 bolt to the Boxster trans, does that mean that the Bentley W12 twin turbo (IMG:style_emoticons/default/cheer.gif) |
| ClayPerrine |
Oct 21 2012, 05:01 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I did some measurements of a Boxster up on a lift to see if the whole rear suspension would fit under a 914. It will... but you could not do it without flares. And it is one of my long term goals. BTW... the perfect 914 (IHMO) 911RSR front suspension. Boxster S brakes. Boxster rear suspension. Boxster transmission. VW W12 motor. The W12 will bolt up to a boxster transmission with no adapters. And it is shorter than a Porsche six. Can you say "914-12"???? There's a school in Sweden that has made a 014 on a Boxster chassie.... If the W12 bolt to the Boxster trans, does that mean that the Bentley W12 twin turbo (IMG:style_emoticons/default/cheer.gif) Yes, all the W12 blocks are the same. So it would bolt to the Bentley W12 twin turbo, and the W16 also. |
| justinevert |
Oct 22 2012, 07:16 PM
Newbie ![]() Group: Members Posts: 16 Joined: 9-September 10 From: Texas Member No.: 12,157 Region Association: None |
I did some measurements of a Boxster up on a lift to see if the whole rear suspension would fit under a 914. It will... but you could not do it without flares. And it is one of my long term goals. BTW... the perfect 914 (IHMO) 911RSR front suspension. Boxster S brakes. Boxster rear suspension. Boxster transmission. VW W12 motor. The W12 will bolt up to a boxster transmission with no adapters. And it is shorter than a Porsche six. Can you say "914-12"???? There's a school in Sweden that has made a 014 on a Boxster chassie.... If the W12 bolt to the Boxster trans, does that mean that the Bentley W12 twin turbo (IMG:style_emoticons/default/cheer.gif) Yes, all the W12 blocks are the same. So it would bolt to the Bentley W12 twin turbo, and the W16 also. Now this is getting interesting!!!! Justin |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:01 AM |
