My fuches restoration underway, using your guys advice |
jsayre914 |
May 14 2008, 12:18 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/biggrin.gif) So I started yesterday. I pulled off the rubber, (weel it was the garage down the street) but I did pull the valve stems out. (IMG:style_emoticons/default/smile.gif) Next i washed the wheels with a little Gunk engine bright. Next I used aircraft aluminum Paint remover...2 coats with a soft brillo. They looke pretty good already. THEN I used the oven off three coats 10 min each. I have no idea what i am dooing But I washed them good after and dryed them with a towl. That is how far I got ....
The look absolutly terrible (IMG:style_emoticons/default/sad.gif) but not for long (IMG:style_emoticons/default/smile.gif) Im still not sure If I got all the anidize off, the only way to know for sure is to start with the polish compound right. Then it will be obvious right? Attached image(s) |
jsayre914 |
May 14 2008, 12:19 PM
Here is where Im at currently
VaccaRabite |
May 14 2008, 12:26 PM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
make sure none of them are cracked before you get too far into them. I seem to recall that the 4 bolt fuchs are crack prone.
Zach |
gopack |
May 14 2008, 12:28 PM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
The easy off (if is the lye [or sodium hydroxide] type) is to remove the anodization. The only way to get the anodization off of aluminum is to use a strong base such as lye. As I understandit, the newer formulations of easy off no longer have lye in them, so check the label.
Also, and again , I am not sure, but I think that the black areas on some 5 lug fuchs is black annodized, but your 4 lug ones look as if it is painted based upon the pics. EDIT: looks like the "heavy duty Easy-off still contains lye! easy off |
jsayre914 |
May 14 2008, 12:52 PM
Does this mean I need another coat of Easy Off (IMG:style_emoticons/default/sad.gif)
or Is this just what it looks like after Attached thumbnail(s) |
jcd914 |
May 14 2008, 12:59 PM
I am sorry if if I am hijacking this thread but this seemed to fit in here.
I am getting a set of 2.0L Fuchs wheels with a couple of 914s I am buying and the PO has bead blasted 2 of them and then polished 1 spoke on each wheel. I don't think bead blasting is a good idea with alloy wheels but I am thinking I am going to have to bead blast the other 2 wheels and polish all the spoke to get a full set that match. Any thoughts on how to salvage this set of wheels? Is bead blasting OK and I am out in left field? Do I just sell them to some one else? Thanks Jim |
Lavanaut |
May 14 2008, 02:05 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
Im still not sure If I got all the anidize off, the only way to know for sure is to start with the polish compound right. Silly question: do you know that these are real Fuchs? I ask because they've got black backgrounds, which often means they're repros (like the ones on my car (IMG:style_emoticons/default/dry.gif)). If they're not authentic, they may not be anodized... (IMG:style_emoticons/default/idea.gif) I am sorry if if I am hijacking this thread but this seemed to fit in here. Why do people do this? Why not just start your own thread? (IMG:style_emoticons/default/confused24.gif) |
jsayre914 |
May 14 2008, 02:08 PM
QUOTE Silly question: do you know that these are real Fuchs? I ask because they've got black backgrounds, which often means they're repros (like the ones on my car (IMG:style_emoticons/default/dry.gif)). If they're not authentic, they may not be anodized... (IMG:style_emoticons/default/idea.gif) All five have a VW stamp on the back |
zymurgist |
May 14 2008, 02:53 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Good job! Wanna do my tail dragger wheels too? (IMG:style_emoticons/default/laugh.gif)
Eric_Shea |
May 14 2008, 03:06 PM
QUOTE Does this mean I need another coat of Easy Off (IMG:style_emoticons/default/sad.gif) This is exactly why I recommend taking them to a local anodizing shop and have then de-anodize them. I've refinished over 20 Fuchs wheels. The shop that I used to anodize them de-anodized them for free. Bead blasting is OK if they use the right media. If its sand then NO. You will have some serious polishing to do to correct that. Plastic and walnut works fine. Finer particles like glass are even better. |
May 14 2008, 06:21 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Does this mean I need another coat of Easy Off (IMG:style_emoticons/default/sad.gif) or Is this just what it looks like after Now, prior to sanding and polishing, wash the wheels with a heavy mix of Borax and water. If you find Boraxo...that will do..If you can find straight borax, that is better. It will bring them back to the correct color and rid you of the blacken staining that Lye produces... then, soap and water...mild car soap. then you are all set to start sanding and polishing... Good luck. Rich |
jsayre914 |
May 14 2008, 06:37 PM
Does this mean I need another coat of Easy Off (IMG:style_emoticons/default/sad.gif) or Is this just what it looks like after Now, prior to sanding and polishing, wash the wheels with a heavy mix of Borax and water. If you find Boraxo...that will do..If you can find straight borax, that is better. It will bring them back to the correct color and rid you of the blacken staining that Lye produces... then, soap and water...mild car soap. then you are all set to start sanding and polishing... Good luck. Rich (IMG:style_emoticons/default/beerchug.gif) |
quadracerx |
May 14 2008, 10:29 PM
Member Group: Members Posts: 426 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest |
I am usually all about do it yourself...but does anyone know who does the best job polishing...at a reasonable cost? (IMG:style_emoticons/default/smilie_pokal.gif)
If there is someone in the Seattle area...that would be great for me.... (IMG:style_emoticons/default/biggrin.gif) Thanks.... Steve |
Smitty911 |
May 14 2008, 11:08 PM
Member Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California |
MagMasters in Santa Ana, Ca. By far the best polishers around. They won't gind off so much aluminum as to make them unusable.
I'd never recommended Bead Blasting Aluminum, dependant on the media and pressure you could PEEN over any Cracks or Problem areas. Non-destructive Inspection days, sorry. Smitty |
KELTY360 |
May 14 2008, 11:39 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
I am usually all about do it yourself...but does anyone know who does the best job polishing...at a reasonable cost? (IMG:style_emoticons/default/smilie_pokal.gif) If there is someone in the Seattle area...that would be great for me.... (IMG:style_emoticons/default/biggrin.gif) Thanks.... Steve This shop does a great job of polishing for a very reasonable price. It's at the north end of Boeing Field Show Quality Metal Finishing Don Meth 206-762-6717 1115 S. Elizabeth St. Seattle WA 98108 |
jsayre914 |
May 15 2008, 01:02 PM
(IMG:style_emoticons/default/biggrin.gif) I got my supplies........................
.........to be continued............ Attached image(s) |
Lavanaut |
May 15 2008, 01:06 PM
A moment of silence for the clown that gave his nose for your wheel project. (IMG:style_emoticons/default/ph34r.gif)
jsayre914 |
May 15 2008, 01:07 PM
A moment of silence for the clown that gave his nose for your wheel project. (IMG:style_emoticons/default/ph34r.gif) (IMG:style_emoticons/default/av-943.gif) I was gonna give it back (polished) |
flippa |
May 15 2008, 03:23 PM
Advanced Member Group: Members Posts: 3,177 Joined: 7-May 07 From: Boston, MA Member No.: 7,720 Region Association: North East States |
jsayre914 |
May 21 2008, 09:06 AM
Thought I would update my thread......
I finished polishing. taped em up, and I just put a coat of etech a sketch (IMG:style_emoticons/default/biggrin.gif) Almost there! Attached image(s) |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:49 AM |
