Brake Mystery Solved |
Porsche Rescue |
Mar 21 2003, 09:03 PM
In an earlier post I asked for help with brakes that would not bleed. Thought the solution might be of interest. Front calipers were the type with only one bleed screw. PO had reversed them on the front (L-R). In so doing the nipple was on the bottom. Fluid (lots of it!) flowed freely but air remained in the upper part of the calipers. Finally figured it out when I realized that the rears were OK but fronts not. Switched the front calipers from side to side, putting the nipples on the top where they should be. Brakes bled with no trouble. Now the only mystery, how did the PO bleed them?
mskala |
Mar 21 2003, 10:16 PM
Rotiserie (IMG:style_emoticons/default/wacko.gif)
Mar 21 2003, 10:34 PM
Pulled the caliper off and turned it upside down? Didn't bleed them at all?
--DD |
Mar 22 2003, 11:18 AM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i thought about asking that because brad and i ran into the same problem when we were working on Richards black 914. but then i thought, no one would be that stupid, right ? oh well ...
glad you found it! (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 08:45 AM |
