Brake Mystery Solved |
Porsche Rescue |
Mar 21 2003, 09:03 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
In an earlier post I asked for help with brakes that would not bleed. Thought the solution might be of interest. Front calipers were the type with only one bleed screw. PO had reversed them on the front (L-R). In so doing the nipple was on the bottom. Fluid (lots of it!) flowed freely but air remained in the upper part of the calipers. Finally figured it out when I realized that the rears were OK but fronts not. Switched the front calipers from side to side, putting the nipples on the top where they should be. Brakes bled with no trouble. Now the only mystery, how did the PO bleed them?
mskala |
Mar 21 2003, 10:16 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Rotiserie (IMG:style_emoticons/default/wacko.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 03:42 PM |
