111.701.309, Drain nipple |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
davep |
May 18 2008, 06:59 PM
914 Historian Group: Benefactors Posts: 5,143 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Located down in the hell-hole area of the engine compartment these nipples are supposed to drain the basins. They get clogged quickly and cause water to pool. This leads to the rust damage that the hell hole is famous for. Most owners removed these years ago.
Attached image(s) |
StarBear |
Apr 24 2020, 08:24 AM
Senior Member Group: Members Posts: 1,886 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Located down in the hell-hole area of the engine compartment these nipples are supposed to drain the basins. They get clogged quickly and cause water to pool. This leads to the rust damage that the hell hole is famous for. Most owners removed these years ago. Ahhh! Have had two of these sitting in a box for 30+ years and never knew what they were (hence kept them just in case). Now I do! Thanks! |
Lo-Fi Version | Time is now: 19th May 2024 - 01:27 AM |
