Installing a V-8...a few questions, Progress thread & 914 makeover |
computers4kids |
May 28 2008, 10:21 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm installing a chevy 305 with a renegage kit and I have a few questions.
There seems to be plenty of room to leave the battery tray in the OEM position, why do many move the location to the trunk? I have the Renegade wiring harness but no diagram...can someone send me a copy? The exhaust is headers with twin turbo exhaust. Do you remove the stock exhaust heat sheild...it fits either way. Is it good to leave it or remove it? Where do you source your power for the front 'dual fan radiator?' From what I have read it needs to be powered all the time, not switched. Is there a source to tap into in the front trunk or do you run a dedicated line...if so how heavy? I would really love to see pictures of your V-8 914 front end so see what kind of setup you did for valance and cutting the bumper! I'm good on the fender cuts. Stupid Question: The renegade recommends using #8 1/2 metal screws to attach the brackets that hold the coolant hoses to the bottom of the car. It mentions to be careful not to puncture the fuel lines in the tunnel. How can you tell if your'e going to hit a fuel line or not? ...other than just hoping and guessing? Sorry for all the questions... Mark Edited.....thought I would add some before and a after picture since this thread has evolved into a v-8 install/restore/modify thread. The story begins.... Attached image(s) |
computers4kids |
Jun 5 2008, 09:03 AM
Moving along...
Took all the brakes off and getting ready to replace all the rotors, pads and bearings. Probably going to put BMW calipers on the front for now. I'm ready to cut my front bumper...ouch, it's really too nice to cut (early). I lookiing for tips and tricks for cutting the bumper hole and adding a grill to it. I've seen a few out there....how did you do it? It's also time to lengthen the sideshifter rod. I've read about ideas of adding 1/1/4 inch up to 2 inches in length depending on your end goal. I'm not to sure if just some length is going to work for me. My oil pan is not the stock shape. It's some special pan that the PO had installed when the motor was built. It's shallower and has a wider girth...which may protrude too much for the curve of the rod???? I'll post a picture...it's a bit dark...I'll replace later with a better one. Attached image(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 10:42 AM |
