Installing a V-8...a few questions, Progress thread & 914 makeover |
computers4kids |
May 28 2008, 10:21 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm installing a chevy 305 with a renegage kit and I have a few questions.
There seems to be plenty of room to leave the battery tray in the OEM position, why do many move the location to the trunk? I have the Renegade wiring harness but no diagram...can someone send me a copy? The exhaust is headers with twin turbo exhaust. Do you remove the stock exhaust heat sheild...it fits either way. Is it good to leave it or remove it? Where do you source your power for the front 'dual fan radiator?' From what I have read it needs to be powered all the time, not switched. Is there a source to tap into in the front trunk or do you run a dedicated line...if so how heavy? I would really love to see pictures of your V-8 914 front end so see what kind of setup you did for valance and cutting the bumper! I'm good on the fender cuts. Stupid Question: The renegade recommends using #8 1/2 metal screws to attach the brackets that hold the coolant hoses to the bottom of the car. It mentions to be careful not to puncture the fuel lines in the tunnel. How can you tell if your'e going to hit a fuel line or not? ...other than just hoping and guessing? Sorry for all the questions... Mark Edited.....thought I would add some before and a after picture since this thread has evolved into a v-8 install/restore/modify thread. The story begins.... Attached image(s) |
computers4kids |
Jun 10 2008, 09:26 PM
A little more progress today...the focus was bumper updates or should I say "bumper backdate."
I drilled the appropriate holes for the early bumpers (front and rear). I drilled and mounted early fog lights. Using Engman's late bumper block-offs (another great member product) I capped the late bumper shock holes. The engman block-off plates were designed for the fronts, but I made them work on the back holels has well. I then mounted my 74 bumpers on the car to check for fit...yes. When I get around to it...I'll pull the bumpers back off and weld-up the titty holes. Got luck today...everything went right. The front bumper still also needs to be modified for air flow...haven't decided what kind of opening I want to make...or the size of the opening. I've been looking and there's quite a variety out there. I'm really not sure how small I can go and still have efficient cooling here in the hot valley. (IMG:style_emoticons/default/idea.gif) I really like the last picture's breather opening...but looks pretty small compared to others. Attached image(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 07:57 AM |
