Installing a V-8...a few questions, Progress thread & 914 makeover |
computers4kids |
May 28 2008, 10:21 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm installing a chevy 305 with a renegage kit and I have a few questions.
There seems to be plenty of room to leave the battery tray in the OEM position, why do many move the location to the trunk? I have the Renegade wiring harness but no diagram...can someone send me a copy? The exhaust is headers with twin turbo exhaust. Do you remove the stock exhaust heat sheild...it fits either way. Is it good to leave it or remove it? Where do you source your power for the front 'dual fan radiator?' From what I have read it needs to be powered all the time, not switched. Is there a source to tap into in the front trunk or do you run a dedicated line...if so how heavy? I would really love to see pictures of your V-8 914 front end so see what kind of setup you did for valance and cutting the bumper! I'm good on the fender cuts. Stupid Question: The renegade recommends using #8 1/2 metal screws to attach the brackets that hold the coolant hoses to the bottom of the car. It mentions to be careful not to puncture the fuel lines in the tunnel. How can you tell if your'e going to hit a fuel line or not? ...other than just hoping and guessing? Sorry for all the questions... Mark Edited.....thought I would add some before and a after picture since this thread has evolved into a v-8 install/restore/modify thread. The story begins.... Attached image(s) |
computers4kids |
Jun 20 2008, 08:26 AM
Well, the saga continues...
Brakes are all bled and hard as a rock..had to swap out one of the calipers because it had a pinhole in the piston boot. I'm very close to starting the engine for the first time. I went ahead and added two mechanical gauges to the engine (water and oil) since my Ghetty dash gauges are getting a v-8 tuneup from Mark914. The motor cranked for the first time yesterday. Fuel pump isn't turning on so I have to chase that issue down and I've got to figure out how to at least static time the engine...you can't see the timing marks. I've heard there is a trick to adding a hole in the trunk somewhere above the tranny inspection hole and being able to find TDC from there. There is something very un-natural about adding coolant in the engine bay of a 914...just as wierd to see you have a water dripping from your Porsche.. (IMG:style_emoticons/default/laugh.gif) Easily fixed, but still very wierd!! Attached image(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 02:20 AM |
