Installing a V-8...a few questions, Progress thread & 914 makeover |
computers4kids |
May 28 2008, 10:21 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm installing a chevy 305 with a renegage kit and I have a few questions.
There seems to be plenty of room to leave the battery tray in the OEM position, why do many move the location to the trunk? I have the Renegade wiring harness but no diagram...can someone send me a copy? The exhaust is headers with twin turbo exhaust. Do you remove the stock exhaust heat sheild...it fits either way. Is it good to leave it or remove it? Where do you source your power for the front 'dual fan radiator?' From what I have read it needs to be powered all the time, not switched. Is there a source to tap into in the front trunk or do you run a dedicated line...if so how heavy? I would really love to see pictures of your V-8 914 front end so see what kind of setup you did for valance and cutting the bumper! I'm good on the fender cuts. Stupid Question: The renegade recommends using #8 1/2 metal screws to attach the brackets that hold the coolant hoses to the bottom of the car. It mentions to be careful not to puncture the fuel lines in the tunnel. How can you tell if your'e going to hit a fuel line or not? ...other than just hoping and guessing? Sorry for all the questions... Mark Edited.....thought I would add some before and a after picture since this thread has evolved into a v-8 install/restore/modify thread. The story begins.... Attached image(s) |
computers4kids |
Jun 21 2008, 11:47 AM
The previous owner of my project car is/was a bit crafty. After chasing down the wires trying to see why the fuel pump was powering up, I discovered where the PO had installed a hidden sswitch under the dash that breaks the fuel pump circuit...I hadn't recognized it before becuase the switch part hadn't been installed yet...the wire had been cut and connectors had been added. (IMG:style_emoticons/default/w00t.gif)
It lives....after some small diversions, the 305 V-8 roared to life for the first time. The first thought that came to me was "OH MY...., What have I created?" (IMG:style_emoticons/default/post-2-1117899824.gif) This should be a kick to drive. Timing: I have to set the timing and I'm stuck. I don't want to just set the timing by ear...no timing marks visible that I can see. Any suggestions? I can figure out when I'm close to TDC via rockers and compression stroke, but that still doesn't help when there are no marks visible. Looking for ideas? |
Lo-Fi Version | Time is now: 15th May 2024 - 06:48 AM |
