Installing a V-8...a few questions, Progress thread & 914 makeover |
computers4kids |
May 28 2008, 10:21 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm installing a chevy 305 with a renegage kit and I have a few questions.
There seems to be plenty of room to leave the battery tray in the OEM position, why do many move the location to the trunk? I have the Renegade wiring harness but no diagram...can someone send me a copy? The exhaust is headers with twin turbo exhaust. Do you remove the stock exhaust heat sheild...it fits either way. Is it good to leave it or remove it? Where do you source your power for the front 'dual fan radiator?' From what I have read it needs to be powered all the time, not switched. Is there a source to tap into in the front trunk or do you run a dedicated line...if so how heavy? I would really love to see pictures of your V-8 914 front end so see what kind of setup you did for valance and cutting the bumper! I'm good on the fender cuts. Stupid Question: The renegade recommends using #8 1/2 metal screws to attach the brackets that hold the coolant hoses to the bottom of the car. It mentions to be careful not to puncture the fuel lines in the tunnel. How can you tell if your'e going to hit a fuel line or not? ...other than just hoping and guessing? Sorry for all the questions... Mark Edited.....thought I would add some before and a after picture since this thread has evolved into a v-8 install/restore/modify thread. The story begins.... Attached image(s) |
jimkelly |
Jun 21 2008, 02:17 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
make sure your brakes work - stock or 911 - make sure they work well - good pads, good rotors, no dragging, no air in lines - as you are gonna want that thing to stop. jim
computers4kids |
Jun 21 2008, 05:48 PM
make sure your brakes work - stock or 911 - make sure they work well - good pads, good rotors, no dragging, no air in lines - as you are gonna want that thing to stop. jim Absolutely. New rotors, bearings, new pads, new fluid, and stainless lines. Brakes have been adjusted and pedal is good and hard. The calipers appear to be in good working order and the piston seals look good...as well as the MC. I figued I'd get it on the road to see how well things work, then decide what upgrades to the braking system will be needed. Stopping is important (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 08:51 PM |
