Installing a V-8...a few questions, Progress thread & 914 makeover |
computers4kids |
May 28 2008, 10:21 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm installing a chevy 305 with a renegage kit and I have a few questions.
There seems to be plenty of room to leave the battery tray in the OEM position, why do many move the location to the trunk? I have the Renegade wiring harness but no diagram...can someone send me a copy? The exhaust is headers with twin turbo exhaust. Do you remove the stock exhaust heat sheild...it fits either way. Is it good to leave it or remove it? Where do you source your power for the front 'dual fan radiator?' From what I have read it needs to be powered all the time, not switched. Is there a source to tap into in the front trunk or do you run a dedicated line...if so how heavy? I would really love to see pictures of your V-8 914 front end so see what kind of setup you did for valance and cutting the bumper! I'm good on the fender cuts. Stupid Question: The renegade recommends using #8 1/2 metal screws to attach the brackets that hold the coolant hoses to the bottom of the car. It mentions to be careful not to puncture the fuel lines in the tunnel. How can you tell if your'e going to hit a fuel line or not? ...other than just hoping and guessing? Sorry for all the questions... Mark Edited.....thought I would add some before and a after picture since this thread has evolved into a v-8 install/restore/modify thread. The story begins.... Attached image(s) |
computers4kids |
Jun 22 2008, 02:39 PM
The car can now be timed from the driver's wheel well.
How: Using the driver's side heater cable tube which is no longer used in the conversion I bent it up and toward the engine balancer. I then took a white screw ancor and ground the end down so it would fit in the end of the heater tube with the pointed end right next to and in front of the balancer. I then found TDC and placed some white paint at the end of my new timing pointer representing when the engine is at TDC on the compression stroke. Now, using my adjustable timing, I can dial in a curve and point on the underside of the driver's fender well and time the engine. Actually works pretty good. Went ahead and adjusted initial timing without vaccumm advance to 9 degrees at 850 rpm. The engine actually is running and starting pretty good. This weekend, I also stripped the side rockers and the front valance, did any body work necessary and primed them...went ahead and fitted the front spoiler to make sure all fit correctly...I had updated from 75 bumpers. Here's a quetion: When the motor gets to about 185 the two fans automatically come on. Instead of having both of them come on at 185, what about having just one come on at 185 and place a second sender in the radiator that activates the other fan to only come on say at 200 (or whatever)???? Seems like having both come on at once is overkill. Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 14th May 2024 - 07:06 PM |
