Installing a V-8...a few questions, Progress thread & 914 makeover |
computers4kids |
May 28 2008, 10:21 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm installing a chevy 305 with a renegage kit and I have a few questions.
There seems to be plenty of room to leave the battery tray in the OEM position, why do many move the location to the trunk? I have the Renegade wiring harness but no diagram...can someone send me a copy? The exhaust is headers with twin turbo exhaust. Do you remove the stock exhaust heat sheild...it fits either way. Is it good to leave it or remove it? Where do you source your power for the front 'dual fan radiator?' From what I have read it needs to be powered all the time, not switched. Is there a source to tap into in the front trunk or do you run a dedicated line...if so how heavy? I would really love to see pictures of your V-8 914 front end so see what kind of setup you did for valance and cutting the bumper! I'm good on the fender cuts. Stupid Question: The renegade recommends using #8 1/2 metal screws to attach the brackets that hold the coolant hoses to the bottom of the car. It mentions to be careful not to puncture the fuel lines in the tunnel. How can you tell if your'e going to hit a fuel line or not? ...other than just hoping and guessing? Sorry for all the questions... Mark Edited.....thought I would add some before and a after picture since this thread has evolved into a v-8 install/restore/modify thread. The story begins.... Attached image(s) |
computers4kids |
Jul 2 2008, 11:21 PM
I've begun installing the interior of the car. And as usual, the targa rear pad was a pita--getting the two 10mm latch bolts and the little screws for hold the bracket plates back on was a joy.
Installed... rear window, backpad, carpet, seats, seat belts and various interior pieces. I also got started on the Ghetty dash. Gauges should be here right after the holiday (July 4th). Lots still to do...all that little stuff sure eats-up time. The hardest part for this project is finding all the correct bolts and screws. When I bought this car the interior had already been torn out and many parts missing. I'm finally to a point now that I actually know what parts need to be acquired. Attached image(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 02:59 PM |
