Installing a V-8...a few questions, Progress thread & 914 makeover |
computers4kids |
May 28 2008, 10:21 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm installing a chevy 305 with a renegage kit and I have a few questions.
There seems to be plenty of room to leave the battery tray in the OEM position, why do many move the location to the trunk? I have the Renegade wiring harness but no diagram...can someone send me a copy? The exhaust is headers with twin turbo exhaust. Do you remove the stock exhaust heat sheild...it fits either way. Is it good to leave it or remove it? Where do you source your power for the front 'dual fan radiator?' From what I have read it needs to be powered all the time, not switched. Is there a source to tap into in the front trunk or do you run a dedicated line...if so how heavy? I would really love to see pictures of your V-8 914 front end so see what kind of setup you did for valance and cutting the bumper! I'm good on the fender cuts. Stupid Question: The renegade recommends using #8 1/2 metal screws to attach the brackets that hold the coolant hoses to the bottom of the car. It mentions to be careful not to puncture the fuel lines in the tunnel. How can you tell if your'e going to hit a fuel line or not? ...other than just hoping and guessing? Sorry for all the questions... Mark Edited.....thought I would add some before and a after picture since this thread has evolved into a v-8 install/restore/modify thread. The story begins.... Attached image(s) |
computers4kids |
Jul 20 2008, 09:40 PM
Installing the ghetty dash took much longer than I had expected. I took the time to lengthen the wires that needed to be using the correct colored wire from an old harness that I had been saving just for this. Added the rest of the wiring, like senders for the oil pressure, water temperature, voltmeter, clock and all the lights in the new gauges. I did not cut any of the wires of the 75 project car's dash so the whole dash is reversible if someone was so inclined.
It turned out looking pretty sharp! I have to give special thanks to Morphenspectra (james) for doing an outstanding job covering the dash in leather and of course, BigMark Deisgn for customizing a few of my gauges (added volt and water temp gauges and changed my v-8 tach to a non-silver bullet). I also took his advice and I wired a "fans on" lamp at the bottom of the tach to let me know when the fans come on. And finally, I DROVE MY CAR TWO FEET TODAY (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) I couldn't get the transmission into reverse to get out of the garage and it was late and I didn't want to start adjusting the linkage. If my memory serves me correctly, I should be able to adjust the shifter my moving it...I'll have to look up which way. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 04:50 PM |
